Question about Archos 504 500870 Digital Media Player
Loose USB connector, Archos 504
The USB connection is loose. After spending $110 to send it to them (they were told the connection was loose), Archos won't fix it under warranty - want almost the replacement cost to do so. Is there anywhere in the US we can get this fixed - almost impossible to find a repair shop for this overpriced unreliable product.
  • 8,596 Answers
There is nowhere, except in Philadelphia - and they will charge you as much or more than Archos. Mp3 players do not have economical repair services.
Posted on Jun 26, 2008
  • yankeedam Feb 17, 2011
    USB connectors are too fragile for the constant in-out service they get. But I have solved the "loose USB" problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
What type of charger does an archos 504 use
A wallcharger with USB A female port, with an output of 5v and 500mA (also you can buy one with an output of 5v and 800mA, 1A, 2A,...it doesn´t matter because the Archos only will take those 500mA)
Apr 26, 2010 | Archos 504 500870 Digital Media Player
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
My archos 504 wont charge when i connect to my computer
The Archos need to be plugged into an "active" USB port, giving 5volts and no less than 500mA. Some old computers or laptops could´nt reach this performance.
Feb 02, 2010 | Archos 504 500870 Digital Media Player
Where is the reset button on my archos 504?
Take the battery off. Just beside the 4 battery terminal connectors there is a little button about 5 mm (1/4 "). Push it with the tip of a pen for 10 seconds and voila!! Hope this helps.
Jan 01, 2010 | Archos 504 500870 Digital Media Player
No power whatsoever to my Archos 504
There is little documentation regarding the reset. However there is one in the Archos 504. If you take the battery off and look at the connecting Pins of the battery of the main unit. You will see a small Gold Button (looks like the circuit). This is the main reset button. If you Press it all will be good. You will not loose anything unless you have a Main File corrept but at least you will get function back so you can fix the firm ware.
I hope this helps you.
Ed
Feb 21, 2009 | Archos AV 500 400-Hours Video Recorder
Archos screen only
solution found!!!!!!!!!!!!!!!!!!!!!!!!!!! thank you so much for the support of the Archos team. here is what i did to repair my 504
if your "reset" button doesn't help at all, this is what you'll do.
If you power on the unit by pressing and holding the TV/LCD button and power
button simultaneously the unit will boot into a recovery screen. Once in this
screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of
the unit:
http://update.archos.com/4/a504/a504_r1.6.53/a504.aos
before i found this solution, i've already given up on my 504, but now it's back!!!! REBIRTH!!!
thanks once again to Tony H from Archos Technical Support
Jun 02, 2008 | Archos 504 500870 Digital Media Player
Can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Dec 13, 2007 | Archos 504 500870 Digital Media Player
Archos 504
try resetting it via the button under the battery cover next to the hard drive, and if not, connect it to your pc, and format it as quick as poss.
Dec 09, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
128 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
