Ecc error when checking hard disk - is it a sign of a failing hard disk or can it be formatted and operate ok?
Nope, i googled and think you need a new hdd ... having the same problem
Posted on Jun 27, 2008
Ex. hard drive will not open windows say windows will not even formate
If windows will not format the hard drive then the HDD is probably bad. Depending on the operating system you're trying to load, if it's Win XP or earlier you can still use DOS to format the drive then try loading windows onto the drive. Windows will want to format the drive again when you load the disk and that's ok because it will format the disk from FAT32 to NTFS. If it still fails then You more than likely have a bad disk that cannot be written to. One other thing you can try is to boot to command prompt and type in sfc /scannow Make sure you have windows inserted in CD drive. This will check your system if Windows is already loaded on the drive but you're having a hard time booting to it. Hope this helps
Oct 29, 2013 | Computers & Internet
Dell Inspiron 570 loud hard drive hum.....(?)
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Nov 23, 2011 | Dell Computers & Internet
Before formatting my laptop i transwereed all my data to my external hard disk. after formatting when i trnswering the data from hard disk to laptop the error comes redundancy check error mostley in...
Hi jrawat7,
A Cyclic Redundancy Check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
Rule out problems with your computer Start by Defragmenting your disk. Click the Windows or Start button in the lower-left corner of your computer screen and select Control Panel. Click the System and Security icon. Choose Administrative Tools, then Defragment your hard drive. This will clear up clutter on your hard drive that could be causing the error
Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the Tools tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
Don't Forget to say Thanks. Thanks for using Fixya.
Feb 05, 2011 | Computers & Internet
Asks me to When I run my recovery disk that Acer sent me this is what occurs, System disk runs and loads fine I F12 as instructed by Acer and then wait Asks what language I want instruction in I choose...
Either you DVD is corrupt, OR the DVD reader is not working correctly. It seems the reason the restore failed, is that it "Thinks" the Hard Drive is corrupt, too corrupt to replace the OS on...
The only thing to try now, is to get a Windows install DVD, put DVD in drive and boot from the DVD, then try to install with that, when you get to installing and it asks if you want to Format, do so, format Full NTFS. Then try to proceed to installing. If this too fails then you will need to replace your hard Drive, quite a simple matter.
Mar 06, 2010 | Microsoft Windows Vista Home Premium with...
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Error with operating system
unplug everything. take out Your hard drive. put Your hard drive back in plug everything back in and try again. That is what is called a hard boot. If that doesn't work then You hard drive is junk. You will need a new one. Hope that helps.
May 24, 2009 | Toshiba Satellite A300-ST6511 Notebook
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Please try changing the HDD. If same thing happens the problem may be with ur O/s Cd or the Mother board
Please let me know this is used machine or New one. If new one please take a different O/S cd and install it.
If you are installing XP and your HDD is SATA then you need sata drivers.
Mar 07, 2008 | Toshiba Satellite 1905-S301 Notebook
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
