Question about Soleus CFM-40 Dehumidifier
Soleus CFM40E Fan runs, no dehumidification
  • Cupp777 Feb 09, 2009
    Fan will constantly run but it never collects water. I can feel the heat from the compressor at the back of the unit, but not sure it is working.
  • lpipenur Apr 17, 2009
    My 4 year old model has the same problem. It was working fine until I shut it off for a long period of time. I'm thinking it will be cheaper to buy a new one than to spend the money shipping and repairing unless there is a quick fix.
    Would appreciate input if anyone finds a solution.
    Scholar:
  • 117 Answers
Http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
contact@soleusair.com
Posted on Jan 07, 2010
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
How do i know if dehumidifer is is low on freon not taking much water out of air
Hi, Usually if it is low it will start to freeze up but if you have a freeze control unit then the compressor just won't run much...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 19, 2011 | Soleus CFM-40 Dehumidifier
My 40 pint Soleus dehumidifier doesn't pull any water into the tank even though the fan blows normal.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jun 18, 2010 | Soleus CFM-40 Dehumidifier
Fan and compressor run but coils not cold and no dehumidification is happening.
If your compressor is running but the coils are not getting cold, then you have a problem in your refrigerant circuit.....Most likely a restriction or a leak with a leak being the more likely of the two.
Apr 30, 2010 | LG Dehumidifiers
Compressor running very hot but almost no cooling. Fan running
make sure the coils are clean both evaporator and condenser,then if there is a capacitor in the motor circuitry,check this,finally if the coils frost,then clear up and frost and clear up time and again,this is a sign of low refrigerant R134a,and this also will make the compressor run hot
Apr 09, 2010 | Haier 45-Pint Dehumidifier
Golstar dehumidifer
Either you are under sized. or it is over heating. 50 pint should be used in 1000sqft area. it maybe over heating or the vents maybe plugged one of these is your problem.
Jan 07, 2010 | Goldstar DH504EL Dehumidifier
My Soleus Dehumidifer is not dehumidifying
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Soleus CFM-40 Dehumidifier
Soleus CFM-40 Dehumidifier Logo
605 people viewed this question
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
