Question about Altec Lansing ATP 3W Computer Speakers
No sound from altec lansing atp3
I have check the fuse and power supply to be working.
the +9v regulator is also working.
i replaced the amp ic TDA 7377 but still no sound at all.
please help.
  • 277 Answers
SOURCE: Altec Lansing ATP3 volume control/power know gone bad
hi im familier with this system but i dont excactly remember where are the screws however the opening methods are all alike look for any screws any where on the speaker look behind the net if thereare any if there are gently shove a flat screwdriver and lift out the net then after all the screws are out there is a small slot souronding the speaker gently shove a flat screwdriver in the corner of the speaker untill there is a small gap do the same for all corners there might be another hook in the middle that it good luck do the same
Posted on Apr 17, 2006
  • 619 Answers
SOURCE: Speakers cutting out at higher volume
Check the power /voltage printed at back side of speaker ,test w/ volt meter /if supply not enough current to drive the amplifier.The sound are very low and humming.
Posted on Jan 04, 2008
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 59 Answers
SOURCE: where can i download a driver for the altec is the best solution for you
Posted on Jul 19, 2009
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
My altec lansing atp3 pc speaker have no power
check the power adapter if its faulty replace it
Jul 31, 2011 | Altec Lansing ATP 3W Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
ATP3 intermittency problem
I've had intermittent speaker problems with these models and it was caused by slight abuse, ( stress on the speaker jacks at the main board located in the main subwoofer cabinet). The problem can lead you to believe its the speakers or the wires but in my case it was a loose solder joint on the main board in the subwoofer. I had to take the subwoofer apart and carefully re-solder the connections of the speaker jacks. I've had no problems since. I've also been a little more careful not to push the jack side of the connection against the wall, kicking with my feet etc..
Aug 03, 2008 | Altec Lansing ATP 3W Computer Speakers
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Altec Lansing ATP 3W Computer Speakers Logo
88 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
