Question about Frigidaire Washing Machines
Front load washer
I just purchased this washer from SEARS and after installing and using the machine it shakes severely at the point that it unplugs itself.
  • Patricia Vega
    Patricia Vega Jun 26, 2008
    Thank you for taking time to help me solve this problem. I think you're 100% right. After doing some research on-line with the manufactures manual I also thought that might be the cause!!!! Again thank you have a nice day!!!!!!!!!!
  • racoline15 Dec 01, 2008
    Brand new Kenmore Frontload Washer model #48102/48106. It shakes violently and smaches into the wall during the rinse cycle. The dryer is stacked on top of it. What could be causing this?
  • 246 Answers
Usually, the problem with frontloaders shaking violently is that shipping materials are still in them (even if you've paid someone to install them). Generally on frigidaire models they have two sets of shipping materials. The first set is a set of 4 shipping bolts on the back panel. After removeing these, on some models, you also have to remove the lower front panel by taking out the screws. On a few of the models you will find 2 yellow metal bars connected to the bottom of the washer and the bottom of the tub. After removing both sets of shipping materials, make sure not only is your unit level, but all feet are firmly on the floor and locked into place. Your machine should have come with a set of instalation instructions that will run you through these steps more clearly, but if you don't have them or are still having trouble, just reply back to me.
Posted on Jun 26, 2008
My clothes are coming out of my Neptune Maytag Washer with little black spots I always dry the washer and have no mold issues that I am aware of. What could be causing these spots?
Hello, unfortunately this was a common problem with that machine , the seal and bearing in the washer tub is worn and the grease is leaking out of the bearing and seal and is getting on your clothes. This is not a cheap repair, in fact I would recommend at this point to purchase a new or even a used washer from a shop that gives you a decent warranty.
Sep 28, 2015 | Maytag Neptune MAH5500B Front Load Washer
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
Feb 24, 2009 | Frigidaire Washing Machines
Trouble balancing a used neptune front load washer
It might not be the leveling of it. Front load washing machines have a lot of power when they go into their spin cycle. Depending on your floor and if the washer is upstairs it is going to shake and make a ton of noise. When I worked for Sears as a tech I had to explain this to a lot of people that just got their first front loaders. Some of them would say that it sounded like a plane was flying threw the house when it would spin. Others said it was like an earthquake. Front loaders don't work good in mobile homes either. Not saying that you have one. Anyway, when these go into spin the have so much force coming from them and all that force goes straight to the floor. If your floor is weak or that washer is in a spot where it is weak it's going to shake. The best thing to do is go under the house and put in a support beam right under the washer. This will get it to lighten up a bit and maybe even fix all together. Give that a try and see how that does. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing machine
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and it costs $800 to replace the unit with the bearings. They will not do anything about it except try to sell you a new washer.
I will not buy this washer again (especially from Sears).
Jan 14, 2008 | Kenmore Elite 45986 Front Load Washer
Sears Front loader washer 417.4412300
Yellow bars, one on each side, shipping brackets, remove them or the washer will shake violently. Catriver.
Jan 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washing machine shakes when spinning out
our's did this, it shook horribly. it turns out one (or more) of the shocks had come out and the technician had to come out and replace the shocks.
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Spin cycle problem
Which machine exactly do you have ?
Aug 31, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
