Durabrand DU1301 TV Logo
Posted on Jun 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my instruction manual and can only get local, non cable channels.
The TV is connected to cable, but I pushed some button, which one I don't know, and now all I can get are local channels. Is there somewhere on line where I can download a guide for this 2005 TV? [I get a lot of snow and "Text Ch 1" as the message]
Sincerely,
Ardi C. Whalen
[email protected]
Bob Citizen
Level 3:
  • Durabrand Master 520 Answers
  • Posted on Jun 26, 2008
Bob Citizen
Durabrand Master
Level 3:
Answers
520
Questions
0
Helped
257920
Points
1220
Go into the menu to channel setup and change the setting from tv back to cable(catv).
2helpful
How do I change my Model #1933 from cable tv to regular tv viewing? ~DeniseGM
A little more information would have helped like the model and make but the short version of what to do is go into the menu then select channel search, let it do its search and it will find the live local channels for you..follow the instructions on screen, it will tell you what buttons to push to save the search..hope this helps some.
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
My tv says no signal on one channel, how do i get that channel back ?
If you are getting an OTA signal, you should check your antenna, any amplifier or splitter and the station's status. The "No signal" message indicates that the signal is not strong enough to be resolved by the tuner.
1) Is your antenna pointing in the correct direction? Outdoor antennas can sometimes turn in the wind. Reset the antenna to the correct direction.
2) If you have a splitter dividing the signal between TVs or other devices, try a direct connection to the one TV that isn't receiving the channel. Similarly, if you have an amplifier in the system, try using the antenna without it. (I have seen an amplifier become a filter for select channels when damaged.) The only solution is to replace the device or omit it. (In my case, some channels require amplification; thus we replaced the amplifier.)
3) Has the station's local transmitter/repeater been damaged? Check their news feed. Towers fall and transmitter components can fail.
You could try and see if another tuner picks up the signal. Some low end tuners are more sensitive to signal strength. If you are getting the station from another source, check with the provider. We recently lost some of the local PBS stations due to problems with the cable provider's feed. Only one TV is connected to the set top box.
I hope this helps.
Need operators manual for tv sony kv2183wr
There are channel select buttons on the front of your tv push those to recieve local stations (if you are watching cable programming look for the cable box remote)
4helpful
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
2answers
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
3answers
Problem with my ltv-19w6 flat screen TV
hi your tv will  not show picture if there is no cable or antenal connected insted it will show u the blue back baground
TV channels
Sounds like it lost programing, if it has an "auto program" feature try that, or some older models need it to be done manualy and have a "add/erase" feature, instructions for that should be in your owner's manual.
Connecting my tv and vcr so i can use the vcr remote control
You can always push "03" on a universal remote programmed to work your TV. A better solution is to connect the devices properly. You shouldn't use the tuner inputs for a VCR/DVD player, or you will get a poorer picture and no stereo sound. See the instruction manual for your player and TV. Use a stereo audio/video cable to connect them and select the proper input. The instructions will hopefully clarify this.
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
