Question about Nintendo 64 Console
Expansionpack doesn't fit in controller as the controller pack did don't know where to put it
  • 62 Answers
An expansion pack for an N64? Learn how to install it here:
http://www.nintendo.com/consumer/systems/nintendo64/hook_expansionpak.jsp
Posted on Jun 27, 2008
Bought Malibu model 8310-2921-08, it doesn't have the power pack instruction sheet, so I really don't know how to use the power pack, please help.
Malibu 8300 appears to be a low voltage lighting fixture.
You might have the digital power pack???
Copy following link for operation, operation tips, power pack troubleshoot, etc.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#digital
If this is not your timer, then add a comment and describe timer in detail.
Sep 04, 2012 | Hardware & Accessories
Do i need a exspansion pack to play games on nintendo 64
Well Perfect dark and excite Bike N64 version the DK64 and the ZElda games need expansion packs because of their higher graphics and mega byte qualities to work. But mario kari64 mario 64 and jamesbond goldeneye and mario tennis and super smash bros dont need an expansionpack then.
Is this soloution helpful yes or no
5 STARS IF IT IS HELPFUL.
Jan 23, 2012 | Nintendo 64 Console
Do i need a expansion pack to play games on my nintendo 64 or can i play with out anything in the port
Well some games will have to require an expansionpack then to work and the games that do not require an expansionpack to work you should be okay then as long as some games don't need an expansion pack in order to play them then.
5 STARS IF THIS SOLUTION IS HELPFULL
I cant use my controler because the green part keeps bliking and wont turn on so i cant play my xbox 360
I had this exact same issue the other day. Changing the batteries did not work for me, but don't cross that off of the list quite yet. This worked for me:
1.) Pop the battery pack off of the controller. This is the only way you're going to be able to turn it off. Wait about 5 seconds and put the battery pack back into the controller.
2.) Turn on your X-Box with the power button ON THE CONSOLE. It should turn ON. If it doesn't, unplug the X-Box for 30 seconds, plug it back in, and try again.
3.) When your X-Box turns on, go ahead and hit the controller's power button. Things should function normally from this point forward.
Please let me know if this works for you!
Sep 30, 2011 | Microsoft Xbox 360 Controller
Bought aftermarket expansion pack and installed to play a game and nothing but "blocks" came up on screen tried removing expansion pack and playing without but had same result think exp pack was...
Well if it was a yobo or not an offical Nintendo expansionpack then you are out of luck> I heard that
if you don't use offical N intendo products the unlicense stuff will destroy the consoles then so you will just have to buy a whole new console.
Aug 31, 2011 | Nintendo 64 Console
My N64 will not turn on. The red light comes on, but the tv says there's no signal.
Have you tried a new expansionpack yet. I tried putting in a new expansionpack for my 14 yearold N64 console and it worked again after that, It might just be that then.
Aug 23, 2011 | Nintendo 64 Console
My 64 has trouble tunring on. are there any quick fixes
Well have you tried putting in a new expansion pack inside of the slot where the expansionpack goes into the console it might just be that then. I had a problem with my 14 yearold N64 console I thought that it was a goner then but i tried a new expansionpack and it worked again.
Aug 20, 2011 | Nintendo 64 Console
My 1996 Dodge grand caravan is not starting up but will turn over. I have installed a new crankshaft sensor, new fuel pump and still nothing. Coil pack is good. No spark from harness connecting to the coil...
Hello fellow auto mechanic. Let's take one step at a time .Your engine turns over because your starter is connected directly to your battery.It's possible that the crankshaft sensor was the the problem, but NO. Also new fuel pump well maybe but not yet. There may be more to this story and as always not what you may have done but what you don't know you have done.
First when you put your key into your ignition and turn to on you should here a noise at the back of your cars fuel tank. The sound will be a whiiiirrrrr sound indicating that your fuel pump is doing it's job and pushing fuel to the engine. It will be a very significant sound and you will know it when you here it. If this doesn't happen go to your power control center under your hood on LEFT side open it and you will find a relay for your fuel pump. This is an easy check because you can pull the relay for your horn LABELED the same, and use in place of your fuel pump relay to see if you can start your car. If this doesn't do it ,one more test look at the relays and find the ASD relay this is the main shut off to your vehicle. Now if this doesn't work it is very possible that you or whoever replaced your fuel pump may have crimped some wires or even forgot to hook up the the plug to the pump. This kind of stuff happens all the time, that's why people are always asking questions.Check the simple stuff first, and I believe you will find your problem. It's probably something very simple , don't get discouraged.
One more thing , why are there so many 96 Caravan problems? Please get back to me on the above and let me know if I have helped you. Don't forget to vote and GOOD LUCK.
Jul 20, 2011 | 1996 Dodge Grand Caravan
I just bought a N64 and the game Donkey Kong 64 from ebay. I played it for about half an hour and the whole thing just froze. Is it the game or the system. I need to know so I can get my money back or if...
Well it might be the expansionpack then because its telling you that the expansion pack going to die on you soon. I had a freezing problem with my aqua N64 console so I put the catriages in halfway and it works amnd try cleaning the console out too. My black one works fine with the expanson pack so its not the expansonpack then.
Oct 07, 2010 | Nintendo 64 Console
Bigger tires
No, you probably don’t want to put bigger tires on your motorcycle. They will probably make it handle worse, not better. To some people, bigger tires may look better, but to those in the know, they make the bike look like the owner doesn’t know anything about motorcycle suspension and steering.
Nov 20, 2008 | 2008 Harley Davidson VRSCAW 105th...
Nintendo 64 Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
