Question about Hitachi 50UX57B 50" Rear Projection Television
Wiring connection from tv to receiver
I cannot find the manual for this tv and I am wondering if there download manuals for making sure I have the correct connections from the tv to my receiver and components
    Problem Solver:
  • 5 Answers
There's an audio out that will work - it's controlled by the TV volume. I've found that it works best to connect the components (DVD, etc...) direct to the amp.
Posted on Aug 02, 2008
I got yamaha htr 5850 350watts i dont have manual and wiring how do i connect to my tv toshiba?
EVER HEARD OF SOMETHING CALLED GOOGLE???
GOOGLE SEARCH! USE IT!!!
yamaha htr 5850
Google
The very first thing on the GOOGLE list is that model on the Yamaha website where you can download the manual.
The second thing on the GOOGLE list is the very manual itself.
Sep 18, 2016 | Yamaha HTR-5850 Receiver
Have a perfect picture but no sound. What can be the problem?
Toshiba says:
toshiba_icon_white.pngIf there is no sound from the TV try the following:
  • Ensure the TV isn't muted.
  • Check that the TV speakers have not been manually turned off in the menu settings. Refer to the User's Guide for your specific model TV.
  • Ensure the input for the connected device (DVD / Blu-ray / Cable / Satellite / Game Console) is set properly on the TV. Click here for help with TV inputs.
  • Check that the connected device audio settings are configured send sound through the audio input connected to on the TV. Refer to your device manufacturers instructions.
  • Make sure the connected device does not require a separate audio connection to the TV
Jan 28, 2015 | Toshiba 50H82 50" Rear Projection...
No tv picture when satellite receiver connected to HT-RC370
make sure you have selected all the right av's from the satellite to the receiver and from there to the tv. dont forget to select the input you connected the satellite too
Apr 15, 2014 | Onkyo receiver HT-RC370 User Manual
Hi i have recently got a lg surround system without a manual, i think all the speakers are set up correctly as i have done a sound test on it and they all seem to make noise however i am having trouble...
You should have 2 RCA jacks on your TV and on the back of your receiver ... a white and a red. These are the left and right audio jacks. Generally, I hook up the audio out from the TV to the DVD player, then from there into the receiver ... this makes it easier to turn off the connection to your receiver if you want to use the TV speakers for news and whatever (by turning the DVD player off). Once the RCA cables are all hooked up, the information should have no problem transferring to your surround sound receiver. Now that the connections are all made, check the settings on your receiver. Make sure that you have the surround sound turned on, and that the receiver has all speakers selected (hunt through the menus and find the "dolby 5.1" or "THX" surround options and turn one on. This SHOULD resolve the problem.
If this did not repair your issue, make sure that all of your equipment that you are running through is all capable of surround sound (if you have a really cheap DVD player like me, it may not be able to handle surround sound). If your TV is surround capable (LCD, Projection, and Plasma TVs are usually all capable of this ... CRT tvs are not always capable) but your DVD player is not, hook your TV's audio RCA cables directly to your surround sound receiver and you should be set. If your TV and DVD player are not capable of Dolby or THX surround sound, then you will probably not be able to use that feature, so your satellite speakers might not work, but the main left and right should still work fine.
One other thing that I have had issues with in the past is the connections on the back of the receiver. If you are using speaker wire (a lot of newer systems have input jacks instead of wire because they are easier to deal with) then make sure you have stripped enough of the wire to make a good connection in the back of your receiver. If you have too little wire exposed, or if you have pushed the wires in too far, the insulator on the wire will block the connection. To be sure this is not the case, be sure that only the exposed part of the wire is sticking into the back of your receiver. Also, make sure that you are not trying to run too much wire between the receiver and the speakers -- if you have a 100ft wire between the system and the speakers, they might not be getting a strong enough signal to work -- you can buy a signal amplifier for your speaker wire, or you can use a shorter wire.
Most likely you have to find the settings in your menu and turn on the other speakers. If the sound test worked for all of the speakers, the connections are all good, and it is the system not telling the speakers to work.
May 26, 2011 | Nintendo Wii Console
TX-8211 FM Stereo/AM Receiver All has been fine
make sure that somehow the wires didn't get loose from the speakers in the back. Protect means that it's overloaded. Did you change the plus wires with minus wires maybe. Check to make sure all the wires are good.
Mar 19, 2011 | Onkyo TX-8211 Receiver
I have a Denon AVR - 391 receiver and was wondering the best way to connect my CD player to as there is no provision for CD player
Sure it does:
http://www.retrevo.com/support/Denon-AVR-391-Receivers-manual/id/23705bh449/t/2/
Analog RCA cables go to anything available: DVD; SAT/CBL; DOCK
and/or
Digital audio goes to whatever is available: COAXIAL (SAT/CBL) or OPTICAL(TV)
Jan 09, 2011 | Denon AVR-787
Wiring the sysytem
First make sure to connect the TV to your receiver the proper way as per your manual .
Usually you should have AUX , VIDEO , TV or DVD .
Make sure once you have connected your TV sound cord to press the correct button from the front of your receiver .
Please let me know what receiver model it is and i will be able to determine the connections and set up .
Jul 14, 2010 | Yamaha Audio Players & Recorders
How to connect sony video camera to yamaha htr 6230? I put the yellow in the video white in left and red in right audio in the v-aux in the front of the receiver. For some reason it is not displaying the...
How are you connecting the TV to the receiver? The receiver offers HDMI, component video and composite video outputs. The one you use will depend on what inputs are available on your TV. Whichever you choose, have the appropriate cables connected at both ends. Then make sure the proper source is selected on the TV and your camera output should be visible. The receiver manual is available for download at Yamaha's site if you need a copy for connection details.
Mar 23, 2010 | Yamaha HTR-6130 Receiver
VIDEO INPUTS NOT WORKING ON TV
Make sure TV is set to the AV input, yellow, red and white wire should be connected to color matching input on tv.
When you turn on the PS3 keep your finger on the power pad for 30 seconds and you should get a message from the ps3 about your input choice.
Let me know if this works, If it dosn't I will download the manual for the tv and try to help with it.
Please rate this solution, the only compensation I receive for my time is a good rating from you.
Lone99star
Apr 28, 2009 | JVC AV-32D104 32" TV
No Sound
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Aug 31, 2007 | Yamaha RX-V2090 Receiver
Hitachi 50UX57B 50" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
