Question about Pioneer VSX-D810S Receiver
Squealing from front channel
I have a loud squealing noise in the right front channel after the amp heats up a bit..... would this be a failing capacitor? If so which one? Thx, G
  • Pioneer Master
  • 1,689 Answers
Probably some components have become thermo sensitive and are on the edge of failing. There are many components in these units, and it is impossible to guess at exactly what has failed. The receiver will require proper trouble shooting by an experienced tech to service it.
Jerry G.
Posted on Jun 26, 2008
serpentine belt is getting old and hard and the cold weather was causing it to slip
check belt condition ( small cracks across the grooves = scrap and get a new one) and check tension
Jan 22, 2016 | Cars & Trucks
2000 montero sport: There's a loud squealing noise coming from the engine. What could be wrong?
Squealing is most common with loose or worn belts, I would start by replacing the drive belt on the front of the motor and go from there, Its easier to troubleshoot a squealing motor if you know that the belt or belts are good.
Oct 20, 2012 | 2000 Mitsubishi Montero Sport
Squealing noise then tump when turning on heater 03 lincon navigator
Your AC compressor on the engine is the likely problem, either the pump is frozen up or the front bearing is frozen up, don't run the system or the belt will burn and fly off and strands you. Get this taken care of right away before winter. Have a local shop listen to the noise to confirm my guess as to the cause.
Sep 18, 2012 | 2003 Lincoln Navigator
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Loud squealing noises when I turn the wheel of my 2000 ford range
It sounds like the power steering belt is too loose, tighten it up a bit but not too much just enough to make slipping belt stop.
Jul 01, 2009 | 2000 Ford Ranger SuperCab
When engine fan engages makes loud squealing noise
Either tighten the fan/drive belt or replace it .. it is loose ...
Mar 22, 2009 | 2000 Mazda MPV
The noise is most likely the serpentine belt. Check it's condition and that of the belt tensioner. It sounds like the belt is slipping, causing the squealing noise u describe. As the belt warms up, it's getting a better 'grip' and the noise stops. Turning on the heat also turns on the a/c in newer cars, this added drag on the belt (one more component to turn, the a/c compressor) would explain why it happens when u turn on the heat. Is the belt original? If yes, it's time to change it, and check the belt tensioner to make sure it's doing it's job of keeping the belt snug on all the pulleys. Let me know how u make out.
Dec 13, 2008 | 2003 Nissan Pathfinder
Squealing noise
sounds like a loose belt!!
Open Questions:
See all Pioneer VSX-D810S Receiver Questions
Pioneer VSX-D810S Receiver Logo
171 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
