Question about Magic Chef CTF2125 Top Freezer Refrigerator
Refridgerator leaking water
I have a Magic Chef Refriderator that leaks water. It never did it until I defrosted it. Can you tell me what to do about this
  • rsmealey Sep 05, 2008
    I have a problem with the defrost unit. I have a Magic Chef side-by-side unit that was purchased in 1995.
    Regardless of temperature setting, the back of the side freezer unit will eventually frost up. As frost accumulates on the back wall of the freezer, inside temperatures begin to warm up. When the inside termperature approaches 50 degrees I will turn off the refrigerator and thaw out the frost on the back wall of the freezer. Once everything is thawed I turn the refrigerator back on. The freezer remains clear of frost for about 2-3 weeks then frost accumulates again. This cycle has been repeated for a couple of years and much food has gone bad.
    Each time I thaw the unit the water pan at the bottom of the fresh food side will fill. The pan will collect water even if all of the ice has been removed from the freezer.
    The fan behind the back freezer wall is working. However, a narrow 1/4" strip hangs from the bottom of the fresh food door. This could be a magnetic strip that holds the door gasket.
    Air flow from the freezer to fresh food side appears to enter at the bottom, is forced up along the sides of the glass shelves, and recyled to the freezer at the top where the freezer fan is located. At one point, I thought overcroweded shelves were blocking the migration of air from the bottom along the sides to the top. However, clearing the shelves did not correct the problem.
    I've discounted leakage of cold air through a leak in the door gasket as the problem. I speculate it just doesn't account for enought loss to be the problem, or explain the pathology of the problem. However, I can feel a bit of air flow at the bottom of the fresh food side door.
    Instead, I have thought the problem was with the defrost unit itself. I guess there are three major components to the defrost unit. I tried putting a circuit tester on the defrost components, but did not get results I could interpret with confidence.
    Any thoughts on diagnostic testing would be appreciated.
    Thanks,
    Bob
    Problem Solver:
  • 9 Answers
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Posted on Jun 26, 2008
Hello we have a magic chef refmodelctf1826arq which started to leak water onto the floor from underneath I can not find the reason why leaking ref is cold, and ice maker working.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Magic Chef Refrigerators
Water pooling under the vegetable bins on the refrigerator floor enough to fill up the cavity and leak out the door onto the kitchen floor. It is Magic Chef CTB1925DR. We have to constantly pull the...
Leo Ponder
imufo2
Aug 30, 2011 | Magic Chef CTB1821AR Top Freezer...
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Water leaking underneath the appliance
It can be that the deforst tray is overflowing due to excessive frosting of the auto defrost.
So look into the rear bottom and remvoe tray to drain out.
If this is not he case then a possible leak inthe defrosting tray on the evaporator.
Sep 14, 2010 | Magic Chef Refrigerators
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
Leaking
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 25, 2010 | Magic Chef CTF2126AR Top Freezer...
Magic Chef CTF2125 Top Freezer Refrigerator Logo
282 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
