Question about Frigidaire FEF376 Electric Kitchen Range
Stove will not turn on
I plugged it in, nothing goes on, when I turn the knob to turn on the element the clock starts but there is no heat on the element, same for when I want to start the oven
  • 413 Answers
The power connections to your stove or the wiring at the plug are incorrect. The neutral connection is missing (White wire)
Posted on Jun 26, 2008
2 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: entire range doesn't operate
skimmerle check your connections where your cord attaches to the stove.may be burnt or loose.if ok check wall outlet also 4 loose connections.i think whats happening is you turn the knob and that allows one side of the power thru to the clock so comes on /then turn off power drops out.give what ive said a good visiual inspectionGod bless,tom
Posted on Jan 01, 2009
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
Replaced the old element in the stove now the stove wont turn on
Check the wires going to the broiler and see if your getting power there.
Oct 03, 2009 | General Electric Stove/Oven/Range Chrome...
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
Whirpool Imperial Series Stove turns off while I'm trying to bake
there is a control board just behind the clock. on that board is an omron g2rl-1a-e-cf, 9vdc, 16/250vac type relay. i replaced that relay with an equivalent wired in one and that fixed the problem.
Jun 19, 2009 | Whirlpool GR460 Electric Kitchen Range
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Entire range doesn't operate
Jan 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Display goes blank, no heat, no oven
This I hope will be an easy solution for you. I think you have a circuit breaker tripped or a fuse if you have a fuse panel.. I am guessing you have an old fuse panel. When you have a fuse blown on a 230 volt appliance and you turn a swith on (like your knob) it feeds back to other circuits on the 120 circuits and will make it do crazzzy things, like making lights and clocks work..Regardless if you have fuse or breaker you dont have the 240 volt to run the range..You only have one120 volt leg powering your stove.
Nov 03, 2008 | GE Kitchen Ranges
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Frigidaire FEF376 Electric Kitchen Range Logo
103 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
