Question about DeLonghi Caffe Nero BCO264 Espresso & Coffee Maker
Wires lay out/schematic
After replaced the diode on the circuit board, the labels of the wires (blue and brown) came off . Now that i don't know which wire goes where. Is there a wires lay out or schematic for this unit? Thank you
  • tonyz123 Jun 26, 2008
    Does anybody have the wires lay out or schematic? Please help. Thank you
I've just started to open mine : the order of the wires, starting from the top of the panel is : brown, pink, black, grey !
Posted on Nov 16, 2008
I figured out and it works now. Thank you
Posted on Jun 26, 2008
VGA cord mag 786N monitor has 9 wires fat wires light blue pinkand whitethen six regular wires orange brown yellow white green and black in what order do they connect to 15 pin male vga adapter
Sweet, looks like something that I'd being doing. Here is one of my schematics for the pin lay out..
26141804-rnsaswimapvq3myhs3omkq3y-2-0.jpg you might need to fiddle with the Vertical / Horizontal Sync wires to figure which are which. Hope this helps FixYa issue..
Have a great night..
Mar 26, 2016 | Computers & Internet
Asko t700 dryer schematic diagram
see the schematic attached. and fix it. Merry Christmas
Dec 18, 2013 | Whirlpool Dryers
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
PM0557523 7500 WATT Vertex Coleman missing Capacitor.Need a wiring Diagram for AVR.0065649 Board I have a new capacitor comming and new Diodes.but I dont see where the wires conect to the AVR board?!
There are at least two AVRs for this generator. The original AVR has the diodes mounted on an external heat sink. The updated AVR has the diodes mounted directly on the circuit board. I have a schematic of the original model with the external diodes but it doesn't have the values or parts on the schematic. I will be more than happy to e-mail you a copy of what I have.
Oct 26, 2011 | Coleman Powermate Powermate 5000W...
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Audiovox radios wiring schematic for harley davidson motorcyc
Hi Shorty122772, for more information on your question please contact the folks at Audiovox and good luck:
Feb 24, 2009 | 2005 Harley Davidson FXST - FXSTI Softail...
How do you wire a transfomer and relay together on a central air.(bryant)I took the wires of and now witch wire goes were.I going to change the two.HELP ME
This may be somewhat difficult depending on the year make and model. I will try to help without this knowledge.
There are 2 sides to the transformer. Read the label to see which is which. One side is labeled 24 volt and the other side is labeled 115 volt.
The 115v side will probably only have 2 wires. A white wire and a black wire. The white one will connect to the common or neutral system. If there is a circuit board it will plug on to the 120v Common terminal (probably marked L2). If the air handler does not have a circuit board, the white wire will connect to the other white common wires by a wire nut.
The Black (hot) 120v wire will connect to the 120v L1 terminal on the circuit board. If there is not a circuit board, read the schematics to find out where to wire nut the black 120v wire to. It will obviously be connected to a 120v incoming hot center after the blower door switch.
The 24volt wires will connect in a similar fashion to the circuit board. T1 will connect to the 24v hot terminal on the board. The T2 will connect to the 24v common terminal. If there is not a circuit board you will need to read the schematics very carefully before proceeding. It may be a good idea to add a 2amp fuseable link on the 24v T1 wire just in the case we are wrong.
The 24v hot wire may be wired in multiple ways without a circuit board. One way is to be wired to the Limit side of the Fan/Limit switch (located on back wall of the burner compartment just above the gas valve. Another way is wired to the gas valve. Please read the schematics located on the blower door. I hope this helps at least a little. Let me know please. Thanks.
Aug 14, 2008 | Heating & Cooling
DeLonghi Caffe Nero BCO264 Espresso & Coffee Maker Logo
329 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
