Question about Frigidaire Washing Machines
FRIGIDAIRE MODEL #FTF2140ES2 FRONT LOAD WASHER THE WASHER TUB WILL TURN TO AGITATE AND THE PUMP DOES REMOVE THE WATER, BUT WILL NOT SPIN TO DRAIN CLOTHES. I TOOK THE BACK COVER OFF AND THE BELT IS IN-TACT.
  • GABRIELSMAMA Nov 10, 2008
    I HAVE THE SAME PROBLEM BUT WHEN IT SPINS IT DOESNT SPIN ALL THE TIME
  • 3 Answers
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Posted on Jan 19, 2009
My Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer will not agitate or spin clothes out. Please HELP!
You should check your serial number at this link:http://www.cpsc.gov/cpscpub/prerel/prhtml09/09292.html
There was a voluntary recall issued on your model number. The serial number will confirm if your machine is affected.
As to your problem, i would still suspect drain pump is struggling or inoperable. However if it seems to drain ok and your pump is still relatively quiet except for a nice mellow steady hum (there should be no rattling sound) then i'd take a look at the pressure switch. The pressure switch sends the signal to begin agitation (water level in tub is full) and spin (water in tub is drained.)
Jan 03, 2013 | Frigidaire Commercial Series FCCW3000FS...
My washer is not spinning. What can I do to fix it?
front load infinity washer will agitate but won't drain and spin at end of cycle; water sits in botton of tub
Jan 17, 2011 | Frigidaire Affinity ATF7000E Front Load...
All the sudden our frigidaire front load washer will not spin, what should I do
typical problem for front load washer is that it stops when it comes to a rinse or spin cycle.there is something blocking the drain pump.in order to drain all the water out of the washer the best way is to use a wet dry shop vac.
attach the vaccum to the end of the drain hose and remove all the water.
once the water is removed the door should unlock.then you can access the drain pump from either the front or rear panel depending on the model you have.some models will have a access panel on the front to check to drain pump however if you do not see anything in the pump.
then the obstruction is in the part of the drain hose that leads from the bottom of the tub into the drain pump.if there is no obstruction found then you need to check the wiring and make sure it is securely attach.
last thing when all else fails replace the drain pump.There times the door lock mechanism has failed
Jan 13, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Loader won't drain after cleaning out tube?
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jul 14, 2009 | Frigidaire FTF530FS Front Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire Front loader nightmare!
Apr 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't spin
See this thread:
Oct 26, 2008 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
338 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
