No problem. If this is a windows passwod, you will need to boot into safe mode by hitting the F8 key at start up. Once you're in safe mode, log in under the administrator, from there you can go into user accounts and clear the password.
Now if this is a bios password, you will need to contact Dell support directly. You will need the service tag and express code from the bottom of the machine. They will give you a master code for the machine to get you past the password. They also require that you are the registered owner of the machine in their files. This is easy to do, there is a tag in the left hand corner of Dell's support page that reads register ownership. The link bellow will take you to the contact info you need to call Dell support. http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=E21A18454B4A6550E030A68F27286358&doclang=en&cs=#1
Was this helpful?
Yes
No
Popular Solutions for Dell XPS M1530 Laptop with
Dell XPS M1530 Laptop with Intel Core 2 Duo Processor T5450...
the cd/dvd drive in my Compaq says the driver is istalled properly but nothing is happening when I...
(More)
the cd/dvd drive in my Compaq says the driver is istalled properly but nothing is happening when I open and insert a disk. Also when I check for solutions it says files are corrupted. I I tried to uninstall as instructed, but it does not work thanks- Guest
Windows failed to start. An error occurred while attempting to read the boot configuration data. I...
(More)
Windows failed to start. An error occurred while attempting to read the boot configuration data. I have no copy of Vista.
I have a HP 6735b laptop and want to connect it to my tv. I have done this but the full screen does...
(More)
I have a HP 6735b laptop and want to connect it to my tv. I have done this but the full screen does not appear on the tv. About quarter of the screen on the left does not appear on the screen. I notice when I connect the cable, it immediately sends the image to the tv. I tried using the function button along with f4 but nothing happens. How can I solve this?
Toshiba Satellite A210-11p (about 2 years old).Screen is blank.Does not load up.Only light on is the...
(More)
Toshiba Satellite A210-11p (about 2 years old).Screen is blank.Does not load up.Only light on is the power symbol.Dvd makes a noise for a few seconds.Tried my lcd tv connected to laptop.Pushed the Fn/f4,f5 and f7 seperately,still no screen display.Any ideas! Please.
