Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Dehumidifier
By jpk1949 on Jun 26, 2008
fan runs. compressor kicks in but no moisture is removed. bucket has not had to emptied in 2 months.
Same Problem
Feb 07, 2009
-   unit checked by authorised warrenty center. Gas gone. leak to small to find. Garbage!-   Guest
Best Solution
posted on Jun 28, 2008
Very Helpful)
greg54308
Rank: Apprentice
Rating: 100%, 2 votes
Check the coils for icing. You may need to remove a cover to see them. IF the temp is much below 65-70 degrees, there is a good chance of icing. Take it upstairs or where it is warm and try running it to see if it removes moisture. If it does, it is probably icing. Raise it off the floor as the temp is higher towards the ceiling. Hope this helps
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
I have a Sunbeam model 2411 humidifier. Cleaning instructions say to remove the housing, but I... (More)
Answer
dehumidifier will not extract any moisture & produces no heat
Answer
what should the humidity setting be if you are trying to pull moisture from wood floors?
Describe your Dehumidifiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifier Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
