Question about Samsung TX-R3080 30" TV
Samsung TXR3079WH Power Failure
The tv is less than 3 years old and turns itself off after only being on for a few minutes. this was our first HD purchase in anticipation of 2/09. All other TV's in the house are 15+ years old and working fine. Did not think I would be replacing the samsung before the others. Help.
  • lester537 Sep 08, 2008
    TV was turned on and then turned off by itself and would not power back up. We have never had any problems before with the TV.
  • Anonymous Nov 17, 2008
    TV is probably 5 years old now.  It turns itself off after just a few minutes and takes a good half an hour before it will turn back on again.  Then it only turns itself back off after just a few minutes.
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Samsung PCK5315RX TV turns off
you tv problem is intermittent have a tech resolder you tv circuit.also have him check the power supply you could be having problem with the component there.probably the regulator diode or cap.good luck
Posted on Aug 04, 2007
SOURCE: 52 HD Samsung tv turns off
I have the same problem with my 56" HD Samsung. It shuts off automatically and then on the power button the word Lamp is light up in green. Sometimes I can turn it back on but other times it won't and I have to wait a bit. It's been embarassing a couple times when people were over for a movie. I believe it might be some kind of overheating problem but would like someone to confirm this.
Posted on Jul 16, 2008
SOURCE: Samsung 50" DLP TV turns itself off
My Samsun DLP turned off and “Screen Freeze”. Fixed it. How? Well, after reading lots of posts I almost purchased a new $136 bulb but decided to give it one more look. Turns out there’s a small switch inside the TV that needs to be depressed at all times. Samung put this switch there to turn the TV off if the rear panel is removed to protect people from harmful UV radiation. I just moved into a new apartment so it must have become unsettled.
I took my back plate off, pushed the button up and down several times then carefully replaced the panel. Note, the panel has a sort of plastic finger jutting out. Make sure this finger is firmly pressing the switch down. If not, wrap some tape around it to make the finger fatter. Dude, use black electrical tape so you don’t start a fire, OK?
So, my TV came back on and I danced a little jig in the living room. Then I started switching channels and everything froze when I got to channel 68. This didn’t look good. I read more posts about people getting this and simply returning the TV. Oh no! Well, I unplugged the TV several times and got bupkis. Frustrated, I finally pulled the power strip off the wall and plugged the TV into the wall. I got a blue screen and when I switched the channel back to 5 it started working. Danced a little jig. Plugged the antenna power into the wall, got better reception, channel surfed to 68 again (don’t ask), and got screen freeze . . yet again. Why? Unplugged the TV several times and got bupkis.
Then the bulb in my head finally went on. My Samsun does NOT like channel 68 but I could NOT get it back to channel 5. Every time I plugged the TV back in it turn on at channel 68 and froze. Ah, unplugged the antenna again, got the blue screen . . again . . and I was able to change the channel back to 5. Danced a little jig.
Hope this helps sooooooomeone.
Posted on Aug 12, 2009
jhinsincity
  • 616 Answers
SOURCE: samsung television model code hlt5076sx
lamp, ballast or colorwheel
Posted on Dec 18, 2009
  • 122 Answers
SOURCE: Samsung LCD TV LE32A450 turns off by itself and then turns on
i dont know where are you from but in europe samsung gives 2 years full quarantee!try to an authorized center!withthe set give to them the quarantee leaflet and the bill from the shop!
Posted on Jun 06, 2010
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung TV...Turn on tv, it operates for maybe a minute, then shuts itself off and has a consistant clicking pattern, like a relay switch. Sometimes turns itself back on
Not knowing the specific model for your Samsung TV and how old it is, I can only offer this possibility because I've encountered what sounds like the same problem. Certain models of Samsung HDTVs around 3-4 years back have a design problem with their power supplies - they put in the wrong size capacitors (aka "Caps"). After a few years, the capacitors fail, and the power supply also fails. I think it's possible to replace individual capacitors, but most likely you will have to replace the power supply. Unfortunately if it's out of warranty, it will cost several hundred dollars, especially for a home / onsite visit. There is a visible symptom - from 2-6 capacitors on the power supply board will bulge out, as shown in this pic:digizen.jpg
You might try calling Samsung customer service and tell them you are aware of problems with their power supply design, and try to get them to repair the TV for free, especially if you are just out of warranty.
Nov 04, 2010 | Samsung Televison & Video
Tv turns itself off after less than a minute or if lucky after a few minutes or more power light stays on even though tv turns off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 26, 2010 | Insignia IS-LCDTV32 32 in. Television
Samsung TV turns itself off every 10/15 minutes
Solutions?
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
No picture on Samsung LNS4051D HD TV.
Maybe the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
Jul 24, 2009 | Samsung LN-S4051D 40 in. LCD Television
TV turns off and then on again every five to ten minutes!
it sounds like it needs to be cleaned try takeing the back off and blowing the dust out
Jul 15, 2009 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Dec 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Jul 06, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung TX-R3080 30" TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
