Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
My toshiba tv model 50H81
For some reason my tv has a blue tint to the picture what is wrong with it?
Mkjm
Posted on Jul 20, 2008
When I turn on my rear projection tv,the color will float & the picture will shake side ways. My tv is a toshiba 50h81 model ,also it is a HDTV as well .
it's capacitors on the three line board. difficult to replace. I would recommend taking it to A professional. It will get worse over time.
Dec 09, 2012 | Toshiba Televison & Video
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
Blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
When we turn on our Toshiba 50h81, it will work ok for 45-90 minutes, then without warning, the picture and sound will go off and the power light blinks. We have to let it set for awhile (I've never timed...
These Toshiba TVs have a problem on the power board that causes this issue and it is a common one. There are several capacitors on the power board that seem prone to coming loose over time. When they lose connection for a moment the TV's protection system steps in and cuts off power. This causes the 'blinking power light' issue. The last one I repaired was a 43V71 model and I re-soldered one loose capacitor on the power board and it has worked perfectly ever since. Toshiba put out a service bulletin on this problem. It is well known and well worth fixing.
Nov 11, 2009 | Toshiba 50H81 50" Rear Projection...
Hi i need a picture tube (the blue crt) what all models and sizes of Toshiba fit if i was to go used? It is a toshiba 50h81
You can also use picture tube part number 23008517 which is in model 57H81. Please note that these tubes are no longer available frmo Toshiba.
Dan
Nov 02, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba Theaterwide HD 50 inch convergence problem
You will have to spend money to repair it. The Convergence IC's need replacing along with checking all the bias resistors for correct value. Do not attempt to align the Blue manually as you will have a headache once the problem is repaired. A normal repair bill is in the area of $250.00 for a service center to repair.
May 28, 2009 | Toshiba Televison & Video
Toshiba 50h81 has power but no picture or audio
is your high voltage still comming up?
ok turning up screen controls with tv on. what do you see?
Apr 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81
convergence amp ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 16, 2008 | Toshiba 50H81 50" Rear Projection...
T/v picture quality
How is this TV hookup? Whats is the Model number?
Dec 06, 2007 | Televison & Video
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
