Sharp SF-2014 developer
I have an old Sharp SF 2014 copier machine. When I raise the top unit the dust of the developer spill all over the components on the lower unit. I take out the developer unit which is together with the toner unit to clean and to check the problem. I do not find anything abnormal; have changed two foams and want to be sure of the problem before assembling with the new developer.
Can you help me in this case?
Thank you
  • 168 Answers
Hello Gus,
IF the Toner/developer is spilling out towards the rear of the machine then the developer unit is going bad. A common problem with this model was the rear bushings in the developer unit would wear out and start to leak. If you take the developer unit out of the machine, put down some newspaper, and tip the developer unit (OVER THE PAPER) about 15-20 degrees towards the back and see if the Developer/toner leaks out any. If it does then you found the problem.
If it doesn't then you might just have an over toning problem. To check to see if you have an over toning problem, please the developer unit ON THE PAPER, get a philips screw driver, and put it in the rear White gear. You will see a series of gears but there is only 1 that is the located on the END of the Roller with the toner/developer on it. TURN IT CLOCKWISE about 1 turn and see if you see toner spilling out.
If you do, then your machine needs a Developer change.
Hope this helps.
Let me know if you have more questions.
If you need parts for this machine, I have a couple contacts that I can give you and you can see if they have the parts in stock.
Good Luck.
Posted on Jun 26, 2008
Ar5516 developer spilling out
hi 1 might be developer is very poor quality (generic) 2 check biasing in sharp normally it,s developer issuer and also in this model if u turn mag roller while replacing or just turn and re install in your machine will spill developer
Feb 24, 2014 | Sharp AR-M205 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
Sharp SF-1118 Analog Photocopier when i print the image the image was blank come out pls give some tips its very urgent
1.Check the charge unit (upper one) if its intact or dirty with toner particles and clean then the lower corona to see if the wires are broken if yes replace them.
2.Check if there is developer spilled on the corona wires on the transfer charger.If spilled clean the transfer unit.
3.Check if there is developer on the DV unit
Mar 27, 2009 | Sharp Office Equipment & Supplies
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
Sharp Photocopie SF 2035- warm up problem
Dose the copier show a error code? Like a H4??? If so you have a problem with the fixing unit. I do belive it can be reset, but the problem needs to be repaired aswell.
Jul 26, 2008 | Office Equipment & Supplies
Sharp 2025
You have to take out the toner/developer box. Unscrew the top portion(usually blue screws), then separate the two. Dump out the old developer and vacuum out the remainder. OPen the DV bag and slowly poor the dv into the unit evenly. then rotate the DV cylinder with e screw driver at the rear to blend it onto the dv roller. close the unit and reinsert to copier. There is service mode to run the toner into the new developer. You can contact me to find this out.
Jun 12, 2008 | Sharp SF 2020 Copier
128 people viewed this question
