Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
Problem with cable
We just moved our TV to another part of our apartment, and had to activate a previously dormant TV cable socket. When the TV cable is connected to the cable box, there are sparks indicating high voltage. However, there are no sparks when we remove the HDMI cable that connects to our TV. Have you come across this kind of situation before?
Thanks,
  • ks19 Jun 27, 2008
    Thank you. This is helpful.
    Genius:
  • Pioneer Master
  • 1,689 Answers
The device that is connected to the HDMI socket may have a ground fault, or there is an electrical problem in your home.
You should have the cable TV man come out and at least check to see that their cable is electricaly in specs. You may also need an electrician to check the electrical for proper grounding and wiring.
I would not rule out the possiblity that the device being connected to the TV has an internal ground or electrical fault.
Jerry G.
Posted on Jun 26, 2008
I am trying to connect my vcr to my tv and am having many problems. does the vcr need cable? or can it conect solely to a tv? thanks.
If the TV has a scart socket then you should be able to connect it via a scart lead to TV from the VCR. Apart from feeding an aerial lead to the VCR first then out from it to the TV aerial socket it should work fine.
Aug 09, 2011 | RCA VR349 VHS VCR
Television was alright when it was cut off. Next morning cut it on and the picture is all yellow and blue.
Tv is missing a color green,recheck ur tv Ant.hole coaxial cable input.Take the cable apart and reconnect to the Ant.hole again see if this help?Not make a fist with ur hand bang on the tv back cover frame see if the color green come back or flashes?Yes,than the tv CRT video board that is connected to the CRT- picture tube have cold soldering joints around it video board connections sockets,require resoldering the socket joints connections between the CRT video board and CRT tube connections socket.U have tools like a soldering iron,a roll of solders and can do basic soldering work?Yes,this problems just require resoldering that it.
Jun 10, 2011 | Sansui DTV3200 32" TV
No sound on certain channels.
All the apartments complex have it than it not ur tv.It the cable company signal problem.Tell the maneger call talk to the company check the wiring.
Jan 13, 2010 | Toshiba 19LV610U LCD TV
UNABLE TO CONNECT IPOD TO TV
You need a converter for this one end is a headphone jack the other to plug in to your tv...you only having a red and white cord already covers you sound and video
Sep 15, 2009 | Apple iPod touch
This is my modem log any ideas for a solution to my random DC's
The router actually has major issues. First, check the power cord to make sure that it's operating in the right voltage.
If it is, then through the command line type tracert followed by a website. If there is no response from the first address, then it will not detect the router.
If this happens, change the router.
Aug 09, 2009 | Arris SURFboard® SB5101 Cable Modem
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
I am unable to get the dvd to play
just turn on both the dvd player and your tv set...then set your tv program into AV mode or INPUT mode,and connect the RCA cables from the output of the dvd player into the input socket of the tv system...be sure that the colors or the RCA wires must correspond to the two sockets namely the the OUTPUT adn the INPUT..you can now activate your dvd player!!!
Oct 27, 2008 | Polaroid 3211TLXB 32 in. LCD Television
2000 Sony Trinitron TV - Ghost activity, off & on power, now dead
Check and replace the T'Con board. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 06, 2017 | Sony KV-27S42 27" TV
Tv want show
Look at the back of your TV.  Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs.  Wait one second between pushes.  You want to stop just before the source that displays "AV" on TV screen.  It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4.  If you use no cable box, try changing channels on TV to find an active one.  If no luck, make sure your cable service is active (subscription active).  Cable companies disconnect it between residents of an apartment/house.
Oct 19, 2007 | Akai LCT3285TA 32 in. LCD Television
Goldstar 19in TV
First check if the signal source is Ok - Antenna, cable, Cable connector.... One of them is at fault.
Sep 26, 2006 | Sony KV-35V35 TV
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
91 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
