Question about Gateway Computers & Internet
Mbr error and no hard disk found and hard drive write error
    President:
  • Gateway Master
  • 1,314 Answers
You need to replace your hard drive.
Posted on Jun 26, 2008
Operating sistem not found
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
    Note Some third-party programs or disk corruption can damage an MBR especially some virus's.
  • An incompatible partition is marked as Active.
  • A partition that contains the MBR is no longer active.
If you can access the BIOS, check where 1st boot is. I have known some people to place something different in here and it will refuse to boot as it attempting to read hardware that does not exist.
Apr 03, 2014 | Microsoft Windows XP Home Edition
Lenovo c340 6 gb How To Setup
This issue may occur if one or more of the following conditions are true:
·The basic input/output system (BIOS) does not detect the hard disk.
·The hard disk is damaged.
·Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note: Some third-party programs or disk corruption can damage an MBR.
·An incompatible partition is marked as Active.
·A partition that contains the MBR is no longer active.
Step 1: Check all hard disk and interface cables are properly connected and are in healthy state.
Follow the steps from: "Operating System Not Found" or "Missing operating system" error message when you start your Windows XP-based computer"http://support.microsoft.com/kb/321626
Or
Nov 11, 2013 | ErrorExpert
Operating system not found
It may happen due to following reasons:
To solve this problem follow this link:- solution
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 18, 2012 | HEWLETT-PACKARD Hewlett Packard Microsoft...
Problem is that I have just installed a new hard drive in my Acer Aspire 5315 or is it 5135. All this after I have set up in the f2 start up page for the cd rom to be the boot drive and a windows...
This issue may occur if one or more of the following conditions exist:
    Note Some third-party programs or disk corruption can damage an MBR.
To solve this, try one or more of the following solutions:
Verify your BIOS settings.. uparrow.gifVerify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk.The documentation that came with the hard disk should aid you in doing so.
Use Recovery Console..Use the fixmbr command in the Windows XP Recovery (or relevant OS) Console to repair the MBR of the startup partition. Be sure that a virus isn't present on the system and that their aren't any hardware errors as this could prove fatal to your hard disk.
May 06, 2011 | Acer Aspire 5315 Notebook
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
I had booting problems with my HITACHI_DK23FA40-40GB. I suspected MBR was corrupt and used MBRwiz tool I down loaded from internet. And the problem became worse. I cannot even access my hard disk. Disk...
you have to backup the mbr before edit. also try use command Fdisk /mbr command to repair mbr.
also pls try to use bootable recovery disk like hiran boot disk, you can use hbcd menu and disk tools and choose disk genius or data recovery
Dec 25, 2017 | Hitachi TravelStar DK23EA Series DK23EA-40...
Error occured in toshiba satelite 1300 in the hard disk code 0101340000
Error code 0101340000, may be due to hardware issues
1. Faulty hard drive or defective memory
2. Damaged recovery media(CD) or faulty CD ROM
OR
Boot system corrupted,
Hope it helps.
Aug 12, 2010 | Computers & Internet
Why hdd shows mbr error
Because either it was corrupted by a bad reboot or (more probably when considering the age of the disk) the disk is dying. Fix the MBR if possible or boot from a Linux Live-CD, recover all your files and replace the disk.
Jun 21, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Vaio operating system not found.
first check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
May 06, 2010 | Sony VAIO VGC-LV110N PC Notebook
I have a operating system not found
Contact your hardware manufacturerYour best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
Mar 05, 2010 | Sony VAIO VGN-AR630E Notebook
Computers & Internet Logo
136 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
