Question about RCA Televison & Video
I recently bought a converter box DTA800 to go with my sony tv Triniton mod.KV-20FV300. It doesn't seem to work; programing, set-up. Please advise.
  • 22 Answers
Ah, the problem is likely your antenna. Make sure everything is properly hooked up, and that your TV is on and turned to either channel 3 or 4 (whichever the unit requires, or you can try both and see which works) then turn the converter on, and check the manual that came with it for a way to check for your antenna's signal strength.
If your signal is good, then use the menu button on the remote and look for an "autoscan" feature, or "autoprogramming", something along those lines, and let the unit look for channels for you (mine requires this before you can use it, not that it matters because my antenna signal is weak). From there you can access the channels manually.
Hope this helps.
Posted on Jun 26, 2008
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Nov 26, 2012 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Hi i have a Sony tv and it doesn't turn on anymore there's only a red light flashing and the sign shows
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 975 posts to different brand TVs now.
Sep 09, 2012 | Sony FD Trinitron WEGA KV-27HS420 27" TV
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
May 09, 2009 | Televison & Video
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Volume goes up on its own!
Hi, We are Zener
we suggest you reset the tv with a secuence of service
that is exclusive with the remote,
is pressing the buttons(display channel 5 volume + power)
the tv turn on, appears parameters on the screen, only press
8 and enter, all your set get as you buy it.
Note: change any parameter, because you are getting in the tlevision`s memory.
Zener, from Mexico
Bye
Jul 22, 2008 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
hope you got it.
Satya.
Jul 18, 2008 | Televison & Video
Digital TV Converter keeps shutting off
The DTA800 has a Power Saver feature that turns the unit off after 4 hours if it is idle (no volume or channel changes).
Press MENU button, press #5 (Setting/Configuration), press #3 (Power Saver) Select OFF to de-activate this feature (no Power Saver).
This is covered on page 11 of the DTA800 user manual.
Apr 25, 2008 | Televison & Video
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
i bought tv ,just week ago and tv sensor on tv want wwork, that why we cant use remote.
Aug 19, 2006 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
