posted by admpeek on Jun 26, 2008
HD52W67 RCA YR.2005 The picture is concaved the color is shifted slightly to one side. When I went to menu convergence it shut tv off then came back on without the convergence menu there. I was told to check the IC's attached to the heat sink (STKxxx) I do not know where to look or what they look like or what they are,im veary mechanicly inclined and would enjoy the attempt to repair this. Any info would be appreceiated.
Thank you,
Adam
Best Solution
posted on Jun 26, 2008
Look on the board next to the flyback you will see three small brown plastic rectangles. Those are fuses the center one is FL231 that fuse and possibly diode D231 and capacitor C231 is blown thats why the convergence option is no longer on the menu. If you need more info please respond to this sme post so I have access to the info again.
Rating Locked! (?) admpeek has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
GE 46GW 948 46 in. Rear Projection Television
Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Panasonic PT-47WXC43 47 in. Rear Projection Television
Panasonic PT-51G44 51 in. Rear Projection Television
Panasonic PT-51HX40 51 in. Rear Projection Television
Panasonic PT-52DL10 52 in. Rear Projection Television
Can you Help with these Projection Televisions problems?
RCA P56830BL 56 in. Rear Projection...
rca 56in. with no picture /...
In your opinion is there an... Answer This...
Repair Service
Find Projection TV Repairman Near You:
