Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
UE message Sorry, can't find my handbook. Just did a wash and instead of seeing "END" when it finished, I saw "UE" Please advise Thank you
    Novelist:
  • 166 Answers
Peace,
Here is the site to download the user manual!
http://us.lgservice.com/gcsc/btc/hpi/main?tc=owm.command.
OwmCmd&COUNTRY_KIND=USA&LANG_CODE=en&BUYER_COD
E=US000002&COUNTRY_CODE=USA&SERVICE_KIND=1
To clear this code you may want to unplug the washer and then upon replugging it in, try to reboot the machine by turning it on and see if it clears that error!
I think this may solve your problem
let me know that it's okay????
Please give me a good rating before you sign off!
Please give me a good rating !
Posted on Sep 05, 2008
Kenmore elite will not finish a wash. every load no matter the size has a UE code. Please advise.
the ue code indicates that the control detects an unbalanced load in the washer that cannot be redistributed. press the start/pause button and try to redistribute the load. here are some problems that can cause this error code
the washer is not level or not stable. make sure that the washer is leveled properly front to back and side to side. press down on opposing corners to make sure that all 4 feet are firmly on the floor. adjust the leveling legs if necessary.
WASHING TO SMALL A LOAD
laundry can sometimes gather to one side. redistributing the load manually can resolve this issue.
try running the washer without any items added and see if it will spin properly. if not, you could have a problem with the control board or the hall sensor on the motor that detects motor speed.
uE error code 79631512210 Kenmore Elite Washe
May 17, 2015 | Kenmore Washing Machines
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
Hi,i have a samsung washing machine,p1253.model and i keep getting a code UE,and it appears not to be spinning.....please advise what this code means and is it possible to read an instruction manual on...
Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
UE Happens if you overload the washing machine.
CLICK HERE for the user manual.
Hope this helps.
(Dont forget the thumbs up if this helped)
Feb 12, 2011 | Samsung Washing Machines
Goes Through Wash Cycles Empty Or Full Stops At Spin And Says UE About 4 Minutes Before End
An UE Error Code is indicative of a “Unbalanced Error”.
This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Thank You
Sep 08, 2010 | LG WM1814CW Front Load Washer
Unbalanced load, sign UE is on, cannot open the door
UE:
• The load is too small.
• The appliance is tilted.
• Laundry is gathered to one side.
• Non distributable things are put into the drum.
See page 17
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Oct 28, 2009 | LG Washing Machines
Error message UE
out of balanced? adjust your clothes till there even around the bowl. set the machine on a higher water level. cheers
Mar 31, 2009 | LG Washing Machines
Samsung frontloader problem
UE - UNBALANCE ERROR
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
WM1832 CW washer with UE error
You should have access to the sides of the drum. Attatch foam to the either the drum or he outside casing.
The problem is caused by the drum moving too much (because of the defective dampers).
This is a cheaper fix than replacement dampers.
Jan 03, 2009 | LG WM-1832C Front Load Washer
Washing Machines Logo
179 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
