Question about Tomtom GPS
Why does my tomtom beep three times? - Tomtom GPS
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
I need a manual for Tomtom GPS
You posted this question three times. When you post for the fourth time, please include the model of your TomTom device.
Jan 17, 2014 | Tomtom GPS
When I started my tomtom the first time, it started just fine. I conneced to my computer and installed tomtom HOME and it said I needed some upgrades, so I installed them. Now, on power up, tomtom says...
Same problem here. We used a Mac instead of Windows, if that matters??? Have you tried calling Tomtom support? We can't get through and are VERY frustrated! In the last three days, we've called about 10 times and have been on hold forever... like up to an hour! They also have not responded to emails we've sent!
Any help from others out there on this would be appreciated.
Dec 27, 2010 | Tomtom ONE GPS Receiver
Tomtom i need it in english i can not read it
If you unit normally starts with the main menu click change preferences next to the blue arrow, then click the blue arrow three times, then click the icon next to the blue arrow which is change languages.
Jan 03, 2010 | Tomtom ONE 125 GPS Receiver
How can I get the display langauge in english? It reads rekenaar
The icons are the same even though the language is german
Start tom tom:
tap bottom right icon to acknowledge warning
once map comes up tap map anywhere
tap on wrench icon to enter setup
tap on the triangle pointing right 5 times or until you see the three flag icon
tap on three flag icon english us should be 8 choices down
have fun, below is the manual for youtr tt1
Oct 22, 2009 | Tomtom ONE GPS Receiver
Requesting contact number for help by phone
TomTom One has a number of built-in sounds that it uses for alerts
beeps, bells, cows and boings.
There are two times when you might hear these:
1. when it nears a POI
2. Going too fast
and you can change these two setting(depends on the model you used).
you can download manual at
tomtom website ----> support scroll down at the right hand side click Find downloads
hope this help
if it help rate the Solution Please
Apr 15, 2009 | Tomtom GO GPS Receiver
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
My Tomtom ONE keeps changing screens & won't stay put.
i had same problem, change internal battery and you will be sorted
Nov 05, 2008 | Tomtom ONE 3rd Edition GPS
GPS Logo
269 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
