Question about Sonic Computers & Internet
Bougth in my 2004 Compaq; work fine; Last week tried using no sound no recording.
  • 22 Answers
It's possible your volume has been muted. Look down where your clock is, if there's a small speaker icon, click it once. A menu will pop up with the volume controls, and if the "mute" box is checked all you have to do is uncheck it. If the slider is at the bottom of the box, slide it up until you have sound.
If there is no speaker icon, do this: Click Start. Click Control Panel. Double-click Sounds and Audio Devices. This will bring up the sound control, and you need to check the box beside "Place volume icon in the taskbar". Also, there's an option to mute the volume above that; uncheck the box if it's already checked. This will keep the speaker icon down by your clock so you can adjust the volume anytime.
If this doesn't solve your problem, check that your speakers are plugged into the right hole in the back of your PC (not in the microphone jack). There will be little pictures beside each of the jacks so you know which is which. And if your speakers themselves have volume knobs/buttons, make sure they're turned up.
If none of this is helping you, your sound card may have come loose or become defective, so you should have a professional inspect it and possibly replace it. But it's very, very likely that your volume is muted or your speakers are unplugged. You can try using headphones if you think your speakers may be defective!
Hope this helps!
Posted on Jun 26, 2008
I have a 2004 chevy trail blazer ext 4 wheel drive does not work used it last week and was fine
When you switch from 2HI to 4HI, you should hear two distinctive sounds from under the truck, one is the transfer case actuator and the other is the front differential actuator. If you hear both and you still do not have power going to the front wheels, then there is a problem with the front disconnect assembly.
Oct 30, 2011 | 2004 Chevrolet TrailBlazer
The mike of my headphones is not working.Even the inbuilt sound recorder of windows XP can't record any sound from the mike..The mike is working fine in other Laptops.I have installed all the...
make sure that your mic input is not muted. look under control panel/sound and audio devices, then under your microphone, select "volume" and make sure the input is selected (with a chack mark in the box under the mic volume control) and not muted.
Oct 12, 2010 | Compaq Presario 700 470024-192 Notebook
2004 Jeep Grand Cherokee Trouble Starting
if the battery is weak,it does not have the rpm needed for the computer to start the vehicle.
if your immobilizer is kicking in,it will not start.
get the electrical checked out.
Apr 20, 2009 | 2004 Jeep Grand Cherokee
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
No sound coming out of my laptop it's been working perfectly for almost a year until last week when I unplugg me headset and the sound is not coming out!built in speakers but if I plug in my headset it...
you could try to use system restore, to restore it back to an operational point before last week.
reboot with the headphones in, then take them out, then restart again.
Nov 12, 2008 | HP Computers & Internet
Compaq presario c772tu inbuilt mircophone not working
You may need to adjust the sound sttings for this device. Also, check to see if you have the drivers this device.
Jun 27, 2008 | Compaq Presario 700 470024-192 Notebook
Nx7010 mic problem
Did you check the sound settings for the mike?
May 08, 2008 | HP Compaq nx7010 Notebook
Computers & Internet Logo
Top Sonic Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
