Question about Zenith R57W46 57" Rear Projection Television
FOUND HISSING TOOK BACK OFF, RED WIRE , AND 3 OTHERS ARE TOUCHING AND BURNT. WHEN TV IS TURNED ON , THEY SPARK AND TV SHUTS OFF. FIRST PIC IS THE RED BURNT WIRE 2ND IS WHAT IS IS CONNECTED TO AT THE BACK OF THE TV
  • 1 more comment
  • wdoeh Jun 26, 2008
    cant get pics to attach
  • Anonymous Mar 27, 2009
    the wire from the block which the flyback plugs into going to the first CRT blew a hole and shorted out. i have replaced all of the caps and the HOT plus a few other ICs. i have been told that my flyback is bad. when the power button is pushed, the CRT will blink then a ticking sound from the FB. i have looked for a good part number on the flyback but the 3 numbers that i have brings no results. INFO- MFG aug 2004 zenith r57w46.
    i found a hole burnt through the wire between the block and the first CRT. the block is between the flyback and CRT. i have replaced all of the caps, the HOT and a few more ic's. when the power button is pushed, the CRTs flash then there is a ticking coming from close to the flyback. i was told the flyback is bad. where can i get one? or should i just shoot the TV?
  • Zenith Master
  • 8,617 Answers
Can you send them to my email slinteriors@yahoo.com and I will assist you
Posted on Jun 26, 2008
There is double vision at times, then it goes away.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking pic
*White looking pic
*Halos around objects
*Red/Orange looking pic
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 07, 2010 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
No Power - hissing but no picture
Power supply capacitors are the most likely culprit. Look for bad solder connections as well.
Oct 07, 2009 | Polaroid FLM-3201 Television
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
Jensen VM9312 Stopped working
MAKE SURE U CHECK THE FUSES UNDER THE HOOD.
Mar 31, 2009 | Jensen's VM9312 Car DVD Player
Set dont like to be cold
Resolder all pinns on FBT on the Deflection board.
Jan 16, 2009 | RCA D61W20 61" Rear Projection Television
When set cold it doesnt have pic
check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Jan 15, 2009 | RCA D61W20 61" Rear Projection Television
Have a denon avr 588 surround reciever that does not stay on the on/stand by button has a red light that is flashing it powers on for about 3 seconds then shuts off and then the red light starts flahing
this could be two wires touching on the back connections. one wire touching another ...just one will do this! look close and causing a short (its shutting off is a safety feature so the unit does not overheat)
Dec 08, 2008 | Televison & Video
Tv turns on and sparks in back and shuts off
box about three inches high? does this have a red wire coming out the top. Sound like the flyback, it and the horizontal output transistor need replaced
Nov 30, 2008 | RCA HD56W66 56" HDTV
Zenith R57W46 57" Rear Projection Television Logo
63 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
