I need Tweeter for jbl model jrx 125 - Audio Players & Recorders
    Genius:
  • 1,689 Answers
Visit the site link below. On this page there is a link for the product support.
http://www.jbl.com/home/product_support/default.aspx?Language=ENG&Country=us&Region=USA
Jerry G.
Posted on Jun 26, 2008
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
Jbl jrx 100 popping
Check all electrolytic capacitors on the amp circuit board.
Jun 05, 2012 | JBL JRX-118SP Subwoofer
The tweeters are not working
The crossover caps may have failed, or the tweeters themselves burned out. Using a small 1.5 volt cell touched across the tweeter leads should produce a sound. If not- they are burned out.
Apr 11, 2012 | Harman Kardon Harman JBL LSR2328P Pair of...
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
Jan 29, 2012 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
I have 2 x jbl jrx 115 and 2 x jbl jrx 118s, we set up a power amp to desk and the 118s, into the left hand speakon connection, using a speakon to speakon cable, from the 118s a speakon cable is run out...
In spite of your description it is not quite clear of the connections... In general you should limit the number of speakers connected to an amp output to a maximum of two. I am not sure if you might have more than that in your daisy chain. Let's go over another important thing: are ALL of the amps and the mixer (desk?) powered from the SAME receptacle or power conditioning module? If not, make it so even if you have to run extension cords. The ground bounce of building power at venues can destroy your equipment. The brand/model of the amp(s) and the mixer would be useful to analyzing the problem. It is unlikely the failing battery in a guitar would kill one side of the PA. If the amp is overloaded, the thermal cutout may be disabling part of the amp and the system. Also please verify the RMS capability of your amp. You want the power of the amp to NOT exceed the rating of the speakers USE RMS VALUES... not the fakey "program" or "peak" ratings... those are just advertising gimmiks to show my numbers are bigger than yours... we know that game...
Sep 18, 2011 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
Can a behringer ep 4000 amp push two jbl jrx 125.
Yes, but it will consume all the power the amp has to offer
Mar 01, 2011 | Computers & Internet
Jbl e80 no sound coming from tweeter
Sound like the tweeter is blown, take to local jbl agent for service.
Sep 16, 2009 | JBL Northridge E80 (Single) Main / Stereo...
JRX 125 DJ SPEKER
The JRX series have weak HF drivers, only rated for some 25 watts or so. Are you running in Bi-Amp or straight? Could be bad capacitors in the crossovers. Could also be clipping of your amp, a common cause of failure is using too small an amp and pushing it past it's clean operation limits. Speakers don't like square waves. Was the "Clipping" light flashing on the amp?
Jan 06, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
 Grubhead
Grubhead
