Error 158 - Audio Players & Recorders
  • 8,596 Answers
FDirSync: Err Msg: Error [158] Requestor Not Registered View products that this article applies to. function loadTOCNode(){} Article ID : 99268 Last Review : October 30, 2006 Revision : 1.1This article was previously published under Q99268 SYMPTOMS loadTOCNode(1, 'symptoms'); When a Foreign DirSync, Directory Synchronization with Foreign Mail Systems, message comes into the DirSync directory server, these error messages may appear:
In DIRSYNC.LOG: "3/23/93 11:00:03 | Error [158] Requestor not registered :
PCM:" -or- "3/23/93 11:05:03 | Error [158] Requestor not registered : PCM:NETWORK/POSTOFFICE" In ADMIN's Mailbox: "Requestor not registered :
From: NETWORK/POSTOFFICE/USERID" CAUSE loadTOCNode(1, 'cause'); If the NETWORK/POSTOFFICE are a foreign DirSync postoffice, one of the following may cause the error: • The NETWORK/POSTOFFICE was not defined on the directory server using ADMIN:CONFIG:DIR-SYNC:SERVER:REQUESTORS:CREATE. Without this, the directory server does not accept requests from a requestor. • The REQNAME field in the DirSync message has a typo for the NETWORK/POSTOFFICE name or the directory server has a typo defined for the FFAPI gateway postoffice. • The REQNAME field does not contain a NETWORK/POSTOFFICE. For example: REQNAME=PCM: The Directory Synchronization with Foreign Mail Systems Manual does not clearly explain the need for the network and postoffice name for Microsoft Mail Software Development Kit (FFAPI)-based gateways. Other gateways require only an entry containing one of the predefined types. These types are listed in the "Foreign DirSync" manual. APPLIES TO • Microsoft Mail for PC Networks 3.0
Posted on Jun 25, 2008
American standard error code 158
thermostat error codes for an american standard ... - AllExperts
en.allexperts.com > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
May 31, 2017 | JBL PB10 Subwoofer
DM Error = 3000-5049-7000-158
Unfortunately the error number is meaningless, it does not relate to anything in the file, like a transaction. There is a corruption in the file. Run the Optimiser from your MYOB folder and try to optimise the file. This fixes some but not all corruptions. Otherwise restore a backup. These guys can fix such errors http://www.fghtables.com/
Sep 06, 2013 | Myob Accounting Plus (BPJUBC00) for PC,...
I need a down loadable mauel for model 158-14000
I tried for several minutes to find
158-14000at sears parts. It does not recognize those numbers. You might want to call Sears and see if they can help you over the phone.
Sep 15, 2012 | Kenmore Sewing Machines
Corrupt MYOB data file
Our MYOB 14 .dat file is crashing. We suspect a corrupt entry in the database. The file will open but as soon as we trying to do anything the program closes and produces the following error: MYOB must terminate. Termination Code 1284 Important Details: Error -3000 in DMGTEKey (5037:7000:69) Seems to be the same error every time. We have tried running MYOB's Verify and Optimise tools with no luck. Each time either tool is run the program crashes and displays the error: An error occurred while attempting to compact the database. DM Error = (-3000-5049-7000-158) Restoring from a backup is not an option as last backup was 3 months ago. So looking for solutions to fix the current file please. Will not be satisfied if the solution is to take it to MYOB. Need someone who can actually dig around inside the file and correct the errors??
Apr 25, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
Looking for the manual for the Kenmore sewing machine model 158.1320
here you go you will need your serial number to match to the specific manual but im putting you in the right direction.
kenmore Manuals
Mar 25, 2010 | Kenmore Sewing Machines
153 people viewed this question
 Grubhead
Grubhead
