I cannot get my sound to work on my computer since I had to switch out my DSL cable box
  • 22 Answers
Check to see if your speakers are still plugged in, and that your volume isn't muted or just turned all the way down.
Posted on Jun 26, 2008
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
AT&T just gave me a new Motorola DSL box and I can't get my router to even find the internet which is active. I can only get the router install portion to go just to where it can't find the...
First of all using the Router Install Portion try to do a 'factory reset' or a 'reset to default'  - wait for a reboot to see if any change occur.
Next try to use the cable between your Moto Box and your LinkSys Box in a different port on the link sys. It may sound silly, but it can work very well sometimes.
Nick
Sep 03, 2009 | Linksys Wireless-G WRT54G Router
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How to connect devices to 3-way video switch box
Normally on a 3-way video switch box, there should be 4 ports.
1 ports connects the monitor
3 ports connect the 3 computers video output
Mar 19, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys routetr problem
HI,
The problem can be caused, because of two reasons, one the router profile on the computer has got corrupted and second the router itself. Have you tried resetting the router to factory defaults.. Caution: all wireless security settings and user name and passwords would go back to factory defaults.
1.Disconnect all cable from the back of the router.
2. Shut down your computer and the DSL box
3.Press the reset button, using a paper clip at the back of the router.Keep it pressed for 5 seconds
4. Disconnect the power cord to the router
5. Switch on the Dsl box, wait for the lights to stablize
6. Reconnect the interenet cable and the power cable to the router and power it on.
7 Let the lights stabalise on the router and power on the computer.
Check if that resolves the problem, if not we might need to update the router.
Thanks
Proton
Oct 18, 2008 | Linksys BEFW11S4 802.11b Wireless...
I need help to set up my router on two computers
If you are setting up the router for cable internet click here.
for DSL conection click here.
Sep 04, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
2 0f 4 ports do not work
It sounds as though the ports on the cable/dsl router as bad. There really isn't anything you can do. It just happens. The typical shelf life of those routers is about 3-4 years. You could go out and buy another one or if you just need more ports go out and buy a little 5 port switch and plug it into one of the working ports and your comptuers into the 5 port switch.
MO
Jul 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
No internet connection on my laptops
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
Lost internet connection
Power off the router by unplugging it. Also power off the DSL or cable router. Shut down the PC. Located on the back side of the router is a small reset button. Using a pen press and hold for ten seconds. Same for the DSL or cable. Power every thing back up starting with the DSL/cable, than the router and lastly the PC.
Dec 16, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
