F there There's no ice Please read this entirely to assist you in troubleshooting
this problem. If your ice maker has stopped producing ice
completely, check these, in this order: It may be turned off. Look
for the wire along the right side of the ice maker that looks a bit like a coat
hanger. If the wire is in the raised position, the ice maker is turned off. If
so, try
If your ice maker has a small red plastic lever, lower
it to lower the wire.
If there's no plastic lever, simply lower
the wire.
In either case, the ice maker should begin producing
ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower.
If the freezer is too warm, the ice maker won't cycle properly. If too cold then the
ice maker fill tube may be blocked with ice. If so, melt the blockage using a
hair dryer-but be careful to not melt any plastic parts! Also replace the water
shut-off valve or water-inlet valve, or both, if necessary. The ice
maker head assembly may have broken parts. Look to see if the gears are broken.
Check to see if the small plastic arms that rest against the ice rake are
broken. If the ice maker head assembly is modular and you've found broken parts,
you can just replace it.
