Help! I have a Whirlpool Super Cap. Plus Washer. When starting the wash it just keep running the water but it never fills up. what's going on?
  • dacrue Jun 26, 2008
    Thanks for your help. that was the problem.
  • 246 Answers
This sounds like a siphon condition. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Posted on Jun 26, 2008
Whirlpool 'quiet wash plus' top load washer
the washer is over filling because the float part is bad see the link below for details Whirlpool Dishwasher Overflows Replace Float W10345285
Jan 07, 2018 | Washing Machines
Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washer is leaving blue stains on clothes after washing.
ok kenna ,,open lid and grasp the fabric dispencer from the top and pull straight up,,it well come off,,,next run it under hot water for a few minutes,,now get some bleach and fill dispencer and let soak over night than flush again with hot water,,that should free get your manual go to onthejob
Oct 19, 2008 | Whirlpool LSR7333 Top Load Washer
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool super cap plus over flowing water
The water level switch has a tube attached to the bottom of the outer tub and will not work if there is a hole or break anywhere.
If the tube looks ok then the switch must be replaced.
May 03, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
