Question about Canon Rebel XT / EOS 350D Digital Camera
Built in flash dosen't pop up
I receive error message 5 when I depress the shutter. I cannot use the camera unless I attach my EX 430 Flash.
  • Lemcr Jun 26, 2008
    Unfortunately, the first solution has not helped. I have used a Quantaray lens with my XT in the past 30 days; however, my most recent activity was solely with Canon's EF-S 18-55mm Lens.
    Err 05; DS126071; DC 8.1V; 0320151846
  • 2,071 Answers
Accidental bending of the pins ,at bottom of flash chamber ,can cause also trouble , it seems you have been using a speedlite a lot than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down ( toward the bottom of the camera )the small button which deactivates the pop- up flash even when the speedlite is not attached>Just bend the tab you a little with a jewelers screwdriver ,turn the camera off and on and then it fixed .The tabs needs to be bent up to release the flash deactivation switch try this also dip a Q-tip alcohol and clean the sliding parts of the flash ,this might clean away from gunk made stick.. ..
Posted on Jun 26, 2008
  • 3,037 Answers
Err 05 is when the internal flash is obstructed or the camera doesn't get an reply that the flash open successfully. This problem should be covered under warranty if its an faulty "pop up flash."
Please call Canon at 1-800-OK-Canon or Email them at: https://consumer.usa.canon.com/ir/controller?act=SupportMailerAct&fcategoryid=215&modelid=9430
and they should help fix this problem for you, please let me know if you need anything else
    Genius:
  • 1,226 Answers
this error comes when the setting comes into fault. You need to reset the camera to the default setting..pls take out the battery and then take it for a while ..fix it back and then test the camera..if this not help pls refer to your manual for the exact operation of the unit.
otherwise, consult the vendor for troubleshooting.
mlenavz
  • Emelio Navaja
    Emelio Navaja Jun 27, 2008
    Consult the nearest service center in your location or contact the vendor regarding your problems.
    melnavz
    Master:
  • 638 Answers
Just be careful... and remember, if you screw up your camera, it's YOUR FAULT,
Canon will fix this problem under warranty.
    President:
  • 1,257 Answers
Please reply with the exact error message as displayed and also exact canon model no and its series no.
  • Deeps . Jun 26, 2008
    Try this :
    What I have found is this. With your left hand, get ready to press the
    flash request button near the left side of the lens. With your right
    hand, use your thumb and one finger to prepare to pry up the flash
    head, perhaps using fingernails. Now push the button and pry. With that
    help, it should pop up. Try it a few times for exercise, and then it
    should pop up on its own quite easily. If you don't exercise it for
    another month, then it may stick again. If the camera is already
    displaying Err 05, then it will not do anything for you until you
    switch off, then switch back on again.
    That should be covered in
    warranty if its an faulty "pop up flash." Call Canon at 1-800-OK
    Please let me know about the solution.you may find it difficult but it can fix it.
  • 282 Answers
5 error is a mirror return error.
The reason or this error message is that the mirror not is returning after a shot. To normalize the camera, a second press on the trigger button is necessary. 4. Note that all functions operate perfect, and the mirror slides smooth in its trace.
The 5 error often happens when using 3rd party lenses (Sigma, Tamron, etc.) which cause incompatibility problems. Were you using a non-Canon lens?
Also clean all contacts with a pencil eraser. Do this with your battery contacts as well and try fresh batteries.
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Jan 02, 2010 | Canon Speedlite 430EX TTL Flash
Pop up flash Pops up but does not flash
Sounds like the internal flash is broken. I have seen used cameras advertised with this condition so it is not uncommon.
Aug 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CANON 40D. Had Flash Error code 05. Powered down for 12 hours. Camera now gives message "Busy" when shutter trigger button depressed. Flash works manually and antennae pops-up , Flashes works manually....
Pop up flash locking mechanism needs adjustment or to be replaced . You might be able to do this yourself but the top cover has to come off completely ( the mechanism I am talking about is on the inside of the top cover and is not expensive ).
One reason for sending it in is that if the mechanism ( small electro magnet and the lock ) has to be replaced you will need spare parts and these are not freely available.
Jun 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon EOS 400D and when i turn it on it works fine but when i start to use the flash it doesn't flash i get on the screen ERROR 99 ! what do i do ?
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 14, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99 when I attach lens
I had the same problem with my camera and i found this guide online very helpful in most cases
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
Jan 29, 2009 | Canon EOS-10D Digital Camera
Canon Speedlite 580 EX II
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Error 99 on 30D Canon
Had this problem before and i found this guide online
camera body.
camera should be serviced.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Canon Rebel XT / EOS 350D Digital Camera Logo
100 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
