Question about SanDisk Sansa c200 MP3 Player
My sansa has black screen!
I was listening to my sansa but it wouldnt play one of songs so I threw it across the room and the glass cracked but it still wouldnt play the song so I threw it across the room again and the screen went black it wont reset or go into recovery mode and when i plug it up to the computer it doesnt recognize it when I turn it on the keys light up but the screen stays black.please help me!
  • troblefollow Jun 26, 2008
    thanks but the computer didnt act like it was there
  • 8,596 Answers
It's toast, you troll. If you hadn't damaged the screen, you might have been eligible for an in-warranty replacement, but now you're screwed.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 25, 2008
My Iphone 5c was working fine, its cracked up quit a bit but its been like that for a month or so now. I put my phone down and when i picked it back up about 7 minutes later the screen was black and w
If the front glass is what's cracked, the part called a digitizer, (which is a thin film layer that reads the skin's touch) could be faulty. WHen the glass is cracked, sometimes it's just a matter of time before the digitizer craps out on you.
Feb 07, 2014 | Apple iPhone Smartphone
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
Mp3 player froze while I was listening 2 it...
this was probally caused by a corrupted file...try to play threw ur mp3 player and see with ones are causeing it to freeze then delet them threw your computer
Feb 10, 2009 | SanDisk Sansa e260 MP3 Player
Broken screen
if it is limited to external glass the glass can be ordered separately but if there is internal crack on pdp itself would have to replace pdp. from my experience generally if it limited to crack on external glass there still should be picture so there may be additional damage to plasma display itself
Aug 16, 2008 | Philips BDS 4611 46 in. Plasma Television
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Sansa MP3 M240 No volume when playing songs, says to synch
Where did you download the songs? Napster?Rhapsody? Any online music stores? Try synchronizing them using their software. If you have ripped songs from a cd you may want to rip them again and before ripping them check this option on your windows media player software. Tools > Options then under RIP MUSIC remove the check mark that say's Copy Protect Music or choose the file format as MP3. Then format the device using the windows media player software(for version 10 = click on the sync tab then choose the pencil like icon on the far right, for version 11 = right click on the sync tab choose the player and choose format) use after doing that rerip the songs using the windows media player software.
Jul 14, 2007 | SanDisk Sansa m240 MP3 Player
My Sansa turns off by itself...Help?
This happens to me to but only when Im listening to a long playlist and I haven't switched anything in a while, but if you go to "settings" and the to "auto shut-off" you can set the time you want it to auto shut off, usually it is on 5mins, so when the 5 minutes are up that you haven't touched it, it will shut off, i belive you sett it all the way up to 125 minutes, hope this helps!
Jun 13, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e130
Does the battery need replacing? My screen is cracked and it appears the battery discharges quicker than normally. For now, I check the voltage on my rechargeables before installing them so that I know they are good. Try putting one song on to see if that will play?
Aug 07, 2006 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
