Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water will not dispense
I have a Kenmore rerfrigerator Model 25359482990, and the ice maker is fine, but water will not dispense through the door. When I remove the filter housing and replace the water will pump out fine until the pressure builds up, then the water will no longer dispense. When I try to remove the filter again the filter cap is under alot of pressure and I can hardly remove. I then replace the filter cap, finger tight and the water works for a short time? If I leave the cap cracked then the water will continue to flow, until I tighten the cap. Your help is appriciated in advance, I am at my wits end.
Thanks,
Bob
    Sergeant:
    Champion:
  • 330 Answers
This is a very strange case, maybe I mean Maybe you should drop a little pressure from the main water supply.tight the pressure regulator a little bit and try it.
Maybe I am wrong.
Posted on Jul 10, 2008
No cold water, ice maker works fine but no water from the door
HI THIS SOUNDS LIKE WATER DISPENSER FROZEN.DEFROST FRIDGE FIRST.GOOD LUCK.ALI
Jun 27, 2012 | Samsung Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker filter
No, they do not. If the ice is old it can absorb taste from the air. You can also buy an in-line filter for your unit. Hope this helps!
Jan 15, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
No water but ice is fine
remove the filter and reinstall , it may not have seated into the filter housing it will take a little while to fill the filter cartridge as you hold in the water paddle
you also may have a water valve problem, something in the water valve that goes to the water in the door that is not allowing the water to come through the valve
Apr 24, 2008 | Refrigerators
Ice and Water Dispenser not responding...
had the same problem, there was a component in the front user panel that was shot
Mar 29, 2008 | Kenmore 44103 Side by Side Refrigerator
No water going to the ice maker
Is the sensor that senses a full ice bin clean....it is a little light or it is a lever. If is thinks your bin is full it probably won't run water. There is a separate valve for the ice maker. It may be bad or have a bad connection on it.
Jan 27, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
