Question about Sanyo DS24205 24" TV
Input channels hey, i have the same problem as this guy. I can't play video games or watch dvds on my input channels. I get no signal from video 1 or video 2. I do have the original remote but have no idea how to fix this. thanx
  • 101 Answers
I would try to replace the AV switch IC which directs i/o signals to the tv decoding stage.
Posted on Jul 26, 2008
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
No video signal comes on screen when watching movies and playing games in video 1 signal
Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | Toshiba Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
There is power to the console. We can hear the
Check the input cables coming from the Wii to the TV. Then check to see that your selecting that right Aux channel. On most remotes there is a source or input selection. Pressing this should cycle through all input channel selections. One input should be the Wii signal.
Bret
1-2-1ComputerServices
Oct 06, 2009 | Nintendo Wii Console
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Trying to play ps2 through my pc
if u have a RCA or S-Video input on your tuner look on your remote control for a button called AV press the button and your card will enter in av mode that will be av1,av2,S-video and the card will display your signal from your ps2
Apr 18, 2008 | Computers & Internet
Sanyo DS24205 24" TV Logo
123 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
