Question about iLO MP3 Player
ILO 2GB player
It will play through the usb. when i try to turn it on unplugged it dose not start the screen just flashes on and off and when it is doing this the only way to stop it is to pull the battery.
  • 8,596 Answers
This is, literally, the worst mp3 player ever made. There is no firmware update, formatting ruins it, and there is no support. But, you can try this as a last ditch effort:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
Ilo 2 GB Flash mp3 Stuck on ilo screen.
link your USB port between Computer and ILO player.
1.Click on START at lower left corner on you computer. choose "Explore"
2.look for ILO driver on start manu on left hand side. left click one on it. right hand click you will see the drop down options
3. Choose "Format" BESURE that you are going to format ILO NOT your hard drive. it will ask you again that you really want to format it. "yes"
4. copy new mp3 files to ILO. That will be finished. you can start playing it again.
Hope this help.
Pin
Jul 13, 2009 | iLO (2 GB) MP3 Player
Cannot download
Make sure the lock/hold is not engaged
"Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
Download the correct Firmware
Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware
Click Open to initiate the download
Double click on the ILO or Siren folder icon. There will be 14 icons.
There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
Then click Run - this will open the Install Wizard.
The Install Wizard has the instructions on the screen as you go through it.
Once the firmware has installed, please click the Start menu, then Programs.
Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
-Tha Mp3 Doctor
Sep 25, 2008 | iLO (2 GB) MP3 Player
ILO 2GB MP3 Player Not Working!!!!
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 12, 2008 | iLO (2 GB) MP3 Player
It's blinking on the ilo screen
2)
Mar 09, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player will not power on
2)
Mar 02, 2008 | iLO (2 GB) MP3 Player
Keeps turning off and on
2)
Wont turn on
i say let it dry out for a day or two
Dec 20, 2007 | iLO (2 GB) MP3 Player
Mp3 player won't play wma's and now won't turn on- flashes the iLO main screen
The company no longer supports these players
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 24, 2007 | iLO (2 GB) MP3 Player
Computer locks up everytime I connect my USB cable into the MP3 ilo 2GB player.
Take it back to WalMart and get another one. This is broken.
Jun 26, 2007 | iLO (2 GB) MP3 Player
Windows XP unrecognize ilo 2gb player automaticly
Mar 27, 2007 | iLO (2 GB) MP3 Player
29 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
