External hard drive
I installed a usb external hard drive (from dead pc) to copy files from it.It shows up as a disk drive, but can't open it. I haven't used the install disk from Mad Dog because I don't want to erase the existing files. How can I copy these?
Both systems are XP, loose drive is SATA and I don't have access to another machine set up for SATA to try it on. That's why I tried the enclosure (which is SATA or IDE and works with another IDE drive).
The dead PC is Dell Dimension 8400 & won't boot from onboard drive or Dell disk, tells me "missing or corrupt Windows\system32\config\system file". I was just trying to figure if the drive was bad or what.
Posted on Jun 28, 2008
1) what are the operating systems on the old (dead) and target systems?
2) Try it on a second working system?
3) This sounds like an OS related problem (if it's not a dead hard drive problem). If you're running Windows, the newsgroups/forums run by Microsoft are actually pretty good. E.g. if you're using WinXP, try
microsoft.public.windowsxp.basics or
They can give you help in diagnosing the problem.
Posted on Jun 27, 2008
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How to copy photos from PC to external hard drive?
How to Copy Files to an ExternalHard Drive
External hard drives provide great storage space for movies, music, picturesand other documents you want to keep safe over time. The drives generally comewith either USB 2.0 or Firewire connectors, so they also offer reliable datatransfers at high rates of speed. Setting the drives up is usually astraightforward process, and copying files to them from your computer is a snap.
1. Set up your external hard drive according to its instructions. The two majorsteps in setting one up are connecting it to your computer and plugging it intoan external power source. 2. Install any drivers that camewith your drive so your operating system will recognize it. If the drivers areoutdated, download and install new ones from the manufacturer's website. 3. Open the "MyComputer" panel. You'll see both your regular hard drive (the C: drive)and the external hard drive listed. 4. Double-click the externalhard drive's icon to open its window. 5. Drag and drop any files youwish to copy to the external drive into this window. 6. Right-click the "SafelyRemove Hardware" icon in the System Tray and eject the drive once you'vefinished copying your files. Read more: How to CopyFiles to an External Hard Drive '
Nov 10, 2010 | Computers & Internet
My laptop crashed while the external drive was hooked up by usb. Had to shut both down. Now the hard drive will not show up on any computer as it did before and cannot be opened to be viewed. I need the...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 05, 2010 | Iomega (33654) Limited Edition 500 GB USB...
There is no problem with it i was just wondering how to use it. It didnt comewith any directions and i know you stick it into the usb port but that is all can you help?
Open "My Computer".
Connect the disk-drive into the USB port.
That "My Computer" window will update, to show an additional "drive-letter" ('A:' and 'C:' and 'D:' were previously listed, so now you should see an 'E:' drive-letter).
Open "My Documents".
Click Edit
Click Select All
Click Copy Selected Files
Choose 'E:' as the destination.
Now, you have _two_ copies of all your 'My Documents' files, and you can sleep comfortably at night, because:
* if your 'C:' drive "dies", you have _one_ copy (on the external drive).
* if the external drive "dies", you have _one_ copy of your files on your 'C:' drive.
Oct 23, 2010 | Toshiba 120GB USB 2.0 Portable External...
How do you download files from external drive to a hard drive?
Select the file you want to download to the computer hard disk, right click your selection and click on copy. Open the folder you want to download the file to and right click a space in the folder and select pest. The file will be downloaded to the specified folder.
Aug 08, 2010 | HP SimpleSave 1 TB USB 20 Hard Drive
ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Dec 08, 2009 | Acer Aspire L100 PC Desktop
How do you transfer data from this external hard drive to a new internal hard drive that was just installed
Turn your computer on. Plug the external drive. It should show in My computer window. Explore the external drive (by clicking on its icon in My computer). Point and select all you want to copy (CTRL A selects All) CTRL C. ( all that is selected will be marked for copying). Go to folder where you want to copy the files. Open the folder and CTRL V.
Hope it helps
Sep 07, 2009 | Computers & Internet
Mac will find wd hard drive PC will not
The Mac disk format cannot see or read by a PC, the PC can see the external drive as a device only.
The way around this problem is to format the external drive with the PC, now you can fransfer/copy files to the external drive and when you plug it into the Mac, the MAC can read PC file formats, this also applies to USB memory sticks.
Aug 02, 2009 | Western Digital My Book Essential 1TB...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
