Question about 2wire 1800HG Router (RG1800HG00)
2wire 1700HW - forgot password. numbner under bar code is 8699603351 Thank you, Debbie
  • Anonymous Apr 24, 2009
    forgot the password
Sure,
Go to Setup wizard, and enter the password that in square brackets under the S/N barcode on the first line.
Enter your desired password twice on 2nd and 3rd lines.
That will reset the password to yours. Continue to the end of the wizard, and you are done.
Alex.
Posted on Jul 15, 2008
WHAT IS the security key for 2wire 525 ?
Enter the 10 digit number for password if you have forgotten it. The 10 digit number is found either on the side or under the router below the SN number. If you changed the password and forgot it, then enter the menu to change password. Then when you get the prompt to enter the password, click on the link below that says forgot password. You may need to click the forgot password a second time as well before you see a dialog box that says enter password. Once you enter the 10 digit number, choose your new password, confirm it and enter a hint so you can remember it the next time. Hope this helps.
Jun 22, 2014 | 2wire 2700HG-B Router (2700HGB)
What is 2 wire 284 password
Numbers between the brackets under the s/n # there was a barcode separating the password number in the the brackets from the s/n #,
THE PASSWORD is IN the BRACKETS UNDER THE BAR CODE
Nov 06, 2013 | 2wire Computers & Internet
I want connect my wii to internet wireless i need the key or pass
You can locate the 10 digit Wireless key at the bottom of the product, near the bar code label.
http://support.2wire.com/?page=view&article=60
Jun 23, 2010 | 2wire (1000-000057-000) Modem
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a 2Wire 1700HW router that is locked or encrypted. How do I unlock it? It is old and I'm not with the same internet provider.
First you will need to open the router set up.
Is there any computer connected to the router with the Ethernet cable ?
If not then you will need to connect the computer to the router.
Check the IP address of the computer and open the router set up.
Click here to know how to find Encryption key / password
Nov 27, 2009 | 2wire Computers & Internet
Was given a 2wire modem without the setup CD. Can I use it?
access the modem interface
by typing at the address bar 1920168.1.254
click on broadband link
then bellow that advanced settings
should ask you for a password
clik on forgot password and then still cant remember password
then it will ask you for system key its on the modem and should be 10 digits long in bracketts
on a sticker by the SN no.
type that should take you back to the main page again
broadband link - advanced settings
you should have a primary email address from your ISP
type it in where it says username then the password where it says password
then confirm
then save you should be on the web
Apr 10, 2009 | 2wire 2700HG-B Router (2700HGB)
Install 2wire 1701hg without installation CD
1. pull up browser(ie internet explorer)
2. type 192.168.1.254/setup or http://homeportal/setup in the address field. (click on i forgot my password if you forget it. then if you can't figure out the pw with the hint provided then go click on " i still forgot my password". you can then reset the system password)
3. setup your 2wire 1701 page, double check if key codes are there. it should be 522P-22P4-6262-22AT-F2NV
4. In time zone page, just choose the one then click next.
5. setup connection info page, just make sure the username is your primary email address with your ISP and also the correct password. fill out the username and password and confirm password fields ONLY then click next. And you're DONE!
you just have to wait till it successfully establish a connection.
if you're still having problem after doing that maybe twice or more then i suggest giving your ISP a call. they can also send you the 2wire cd if your ISP supports 2wire modem. AT&T does.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 06, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Do I need to get a new security key?
Usually in 2WIRE the password is the same as the number on the bottom of your router
Nov 18, 2008 | 2wire (1000-400108-001) Router
Connection to my computer of hp photosmart c6300 via belkin adsl2router
3. Open IE beoswer.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire Router cannot connect to K Corp KLS-611 adapter 802.11g
if you wantd to change the type of encryption from WEP to WPA...aside from accessing the modem through 192.168.1.254....this ip is used on 2wire1000hg series, 2wire1800hg, 1701hg, 2701hg-b and 2700hg-b
*then you might need to indicate the modem password
*if you know it...indicate so, if not, click on the link that says "I forgot password", it would give you a hint...if you still forgot it, click on "I still forgot password"
*after that you need to click on "home network" which is the icon on the top portion of the page
*then you need to click on "wireless settings"
*under "wireless security" you would be able to change the "authentication", whether it is WEP-OPEN, or WPA-PSK"
- you could also go to: 2wire.com for help, just go to the support section
- or you could also see some simulators if you need one on shasta.2wire.com
Oct 01, 2007 | 2wire HomePortal 1800HG Router...
2wire 1800HG Router (RG1800HG00) Logo
776 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
