I need to know where i can get a remote to my tv
  • 8,617 Answers
Post the model number and I should be able to post a link where you can get the origional remote or a direct replacement that wont require programming. respond to this same post so I will know what youre needing when you post the model number of your set.
Posted on Jun 26, 2008
GVA remote has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 10, 2012 | Televison & Video
My remote isnt working
Regards.
Jan 04, 2012 | RCA F27676BC TV
It doesn't work
is this a remote to TV or what? I am assuming it's a remote to a TV. If it is not for a TV, let me know, although, the solution is similar to any unit that uses remote control.
There are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Yours sincerely
Elect_Comp
May 14, 2011 | Televison & Video
Will not work...batteries changed and no response
I believe you are referring to the remote control of your TV.
Good luck.
Apr 02, 2011 | Televison & Video
KLV37U-300A Sony BRAVIA Flatscreen TV. TV does not respond to its remote. Remote sends signals (when remote aimed at digital cam I can see the lights go on). Believe sensor on TV not recognizing remote...
Good luck.
Feb 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
Aug 11, 2010 | RCA Universal Remote Control
The code to program my remote control for my tv Prima PH 42R6C''
I need to know the code to program a new universal remote tv for my PRIMA PH-42R6C. I don't find the code and i don't know what kinf remote i need for this tv.
The problem is i lose the remote
Thank's for your help
yvon.rathe@sympatico.ca
Mar 03, 2009 | Televison & Video
Lost codes to program my remote
im trying to connect to my tv and need the codes....its a toshiba tv
Oct 13, 2008 | RCA RCR311B Remote Control
Conia tv remote codes
I have a Conia LCD TV and the remote died, I purchsed a universal remote and without the codes even on search modes could not get it to find the t.v. I found theat DJ Electronics sell replacement Conia TV remotes online. So if you just need areplcement remote, know your TV model number and you can just replce your old remote.
Jan 21, 2008 | Televison & Video
Rca rcr311b remote control
I need to know how to program my remote to my sanyo tv. I lost the book and do not know the code
Nov 10, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
