Removing swival base
  1. HAVING TROUBLE REMOVING THE SWIVAL BASE ON THE TV CANT FIND DIRECTION TRYING TO PUT IT UP ON WALL
  • Anonymous Dec 26, 2008
    i don't see a place to remove stnd from vizio tv
  • Anonymous Jan 23, 2009
    cant remove base
  • 63 Answers
Most LCD TV's have 4 or 5 screws attaching the stand to the set near where the stand slots in at the bottom. The screws might be covered by a plastic panel.
Hope this helps.
Andy
Posted on Jun 25, 2008
How to remove swival base off of a toshiba regza 42xv540 ?
To know more about this, you have to download its repair manual. Its disassemble section will give you all details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Disassemble procedure to many popular brand TVs are given with illustrations.
Jun 17, 2014 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Im having trouble removing the base stand, I'm trying to mount it on the wall. I removed the 4 screws on the bottom but cant get the metal legs off.
Generally the stand is screwed on from the back of the TV. there should be 4 screws that will come out all the way and allow for the stand to be removed
Mar 13, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
How to fit swival stand on model le32b554 32inch
There are 4 screws in the back at the bottom centre of the tv. Remove these and pull out the blanking plate. Next insert the base upright assembly into the tv and re screw in the 4 screws
Mar 07, 2010 | Samsung LE40R74BDX 40 in. LCD Television
How does one remove the Toshiba TV stand. There does not appear to be any levers etc to release it. We want to mount our TV on the wall so the stand needs removing.
ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
Aug 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
Trouble removing snugride base from car
If the base was installed by someone who put their body weight on it to get it really tight, try to do the following:
If you are able, climb in the car and place your knee in the center of the seat base and put your weight onto it. Then, at the same time, try to pinch the clip end of the latch belt (the strap part that is attached to the car seat base) and push the clip away from you (toward the seat) to remove it from the metal latch loop/ring (the part of the latch system that's actually part of your car).
If this doesn't work, you can try to loosen the strap a little while leaning on the base, and then try to push the clip forward and out of the latch ring.
Aug 06, 2009 | Graco SnugRide - Giselle Infant Car Seat
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
TV surface swival security mounts
Madam, in most cases the swivel mounts are fixed at the base of the TVs with a pair of Bolts / Screws and Nuts.
Please check.
Jan 29, 2008 | Televison & Video
Televison & Video Logo
580 people viewed this question
Top Televison & Video Experts
