Question about Kenmore Dishwashers
Technical support My dishwasher keeps saying the dishes are clean and it will not shut off. I cannot start a new load of dishes as long as it is set on clean. What should I do? Thank you.
    Problem Solver:
  • 9 Answers
slappa71
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
you need to remove the blades and strip it to the bottom of d/w under blades and check if it is blocked. if ok undo drain pipe and blow to check if blocked. good luck SLAPPER
Posted on Jun 26, 2008
Filter doesn't self-clean
hello diane,
i would think that unless your model says it is self cleaning then yes it is normal to have to clean the filters on a dish washer. the amount of time between cleans would depend on how dirty your dishes are.
Apr 20, 2013 | Kenmore 24 in. 15932 Built-in Dishwasher
Tip
We had an ongoing battle with white film on glasses and dishes, inside...
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Mar 31, 2011 | Dishwashers
HOW DO YOU TURN IT ON TO WASH THE DISHES
look for the manual of your new DWF612SS Free-standing Dishwasher.... and find the tutorial how to turn it on...
Apr 27, 2011 | Smeg 24 in. DWF612SS Free-standing...
My dishwasher leaves a film on my dishes. i always use the same cleaning products but the problem is new. have had bosch dishwasher since august 2010
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Jan 07, 2011 | Dishwashers
Dishwasher stops during various cycles and does not clean dishes
Dec 30, 2010 | Jenn-Air JDB3610 Built-in Dishwasher
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
LG model LDS5811WW/02 has never cleaned the dishes since first installation. Put clean dishes in and they will come out dirty too! Have tried all dishwasher soap types and brands and drying agents. Always...
if the soap/detergent isn't completely rinsing out of dispenser, it sounds like water isn't directed the top spray-arm. possible a defective vario motor; as it directs water to the water channel that supplies water to the middle and upper spray arms.
Jul 03, 2010 | LG LDF8812 Stainless Steel Built-in...
Motor making noise- Kenmore Elite dishwasher
OUCH. Sounds as if your dishwasher pump is bad. Most pumps need to have water in them to keep them cool and or lubricated. it could be an impeller problem and coul be a cheap easy fix. Or it could be a bearing which is a more expensive fix and a little harder to do. I hope this is an older machine and you may want to go ahead and get a new energy star heat saver. Or if it is a new one just repair it.
Aug 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water not filling dishwasher, dishes and glassess not clean
if this is a new install you must prime by hand for the first load,by this I mean pour in about a gallon of waterthen shut the door run cycle.
Jul 14, 2009 | Magic Chef CDB6100 Built-in Dishwasher
Just not cleaning
run a cycle thru with no dishes and 2 cups of vingar this will flush out the unit then run a normal load should be ok let me know THERE also is a product called dishwasher magic you can run that thru as well but the vingar is cheaper
Mar 15, 2008 | Maytag 24 in. MDBH955AW Built-in...
Dishwashers Logo
125 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
