Question about RCA D52W19 52" Rear Projection Television
Not all channels available
Hello, when I turned on my tv this afternoon not all my normal channels were available. I performed a channel set up and still static on channels 1 through 13. I then plugged a different television into the same cable jack and all the normal channels were available. I'm stuck. Please make all better.
    President:
  • 1,284 Answers
Sounds like a bad tuner or more commonly the connector on the tuner is loose and or broken.
Posted on Jun 26, 2008
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
We have a new sharp flat screen tv 32 inch that has an issue. We DO NOT have cable so it's not a cable issue. The TV freezes when scrolling certain channels. We cannot even turn off the TV when this h
Try pressing and holding the power button until the TV shuts down, then turn it back on and do a channel search (scan) to load channels that are available and see if that works, good luck.
Apr 29, 2014 | Sharp Televison & Video
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Coby 32 in tv won't store my channel memory. When I first got the tv, it stored the channel memory but now I have to reprogram it every time I turn it on.
Hello
When autotuning the set goes throughs all transmitting channels, shows to be receiveing all channles, but seems to be tunes indefinitely, and no channels are locked, the memory IC inside the set has got damaged. In normal case, the TV will tune to all available channels at that tiime, in air or through the cable, whatever the case may be, tune up to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels.
The memory IC i stated above is a small IC with 8 terminals, and can be located very near to system control Ic, at system control section. In some sets, it will be SMD type [Surface Mount Device], and in otheres will be of DIL type [Dual In Line]. If it is a DIL type, it is very easy to replace. If it is SMD type, proper care should be taken when replacing it, not to damage any track on circutit board and nearby components.
Open your TV, locate the IC and desolder it out of the printed circuit board, go for a same type and number, replace it. This will solve your problem.
OK.
Jan 18, 2011 | Coby TFTV3225 32 in. LCD TV
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
Turn the TV on.
2 Hold down on the remote control.
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
RCA D52W19 52" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
