Question about ASUS A7V8X Motherboard
Motherboard problem for a 754 socket
I have an HP Pavilion a635w. i think i did something to ther mother board. i turned off the pc, unplugged the pc and pulled the ram and installed more, when i turned on the pc it just beeps. i turned it off pulled out the new ram & put back the old. Same thing. I pulled all the ram and turned it on, same thing. so i am thinking that i damaged the motherboard. what should i be looking for to determine this? can you tell me what motherboard to purchase so i can get this puppy up and running.
    Problem Solver:
  • 5 Answers
I found this replacement motherboard with a simple google search:
Posted on Jun 26, 2008
Want to upgrade mother board on a6700f. any suggestions?
Here are the specs for the motherboard for the HP Pavilion a6700f -
  • Manufacturer: ECS
  • Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
  • Chipset: NVIDIA GeForce 6150SE nForce 430
  • Memory sockets: 4 x DDR2
  • Front side bus speeds: 2000MT/s (2.0 GT/s)
  • Processor socket: AM2+
  • Expansion Slots:
    • 1 PCI Express x16 slot for graphics card
    • 2 PCI Express x1 slots
  • 1 PCI slot
If you can find something similar you should be ok.
I can assist if you need someone to "review" any replacements you might be considering.
Aug 17, 2013 | HP Pavilion a6700f PC Desktop
How can i find a new mother board for my hp pavilion dv 6000
Hi mvega002...
Go to the following webpage and order the mother board for your HP Pavilion dv6000.
Please take time to rate me
Sep 11, 2011 | HP Computers & Internet
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
5 socket mother board using 2800+ processor failed. Can i get a compatible mother board.
yes you can! compatible motherboards are cheap and easy to find for the socket 754 design compatible with your cpu. with prices going from anywhere from ~$50-$80. great places to shop include frys electronics,, and when something like this happens to you its always a good idea to consider upgrading your computer as well you can find cpu motherboard deals anywhere from $100 to $200 with a huge boost in computing power. if you choose to go this route make sure your ram will work on the motherboard you are considering. goodluck
Mar 05, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
How to get my mother board drivers for sempron
Find out your model of motherboard by running this then google your exact model for drivers.
Jul 21, 2010 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Dec 22, 2009 | HP Pavilion A635W PC Desktop
D845GVAD2 mother board
Well if you want to keep your processor than you'll want to search for a motherboard with the same Socket type. You'll need to know exactly what kind of processor you have. If you have the box you can find out that way. Assuming you put it together your yourself. Or if you really have no clue. You can remove the heatsink off the CPU. And the socket label will be written right under that. (examples could be.. socket A.. socket 378.. Socket 754).
Once you find that. You can find a motherboard with that type and just ensure that it supports your processor and you'll be good to go.
Feb 12, 2009 | Intel Desktop Board D845GVAD2 Motherboard
Pavilion a635w motherboard problem
Hi HotOlds, you did not hurt the motherboard. You did not install the memory correctly. Take the old memory & look at the contacts on the DIMM. There is a notch there & a notch in the memory slot. These two notches must be matched up when inserted. Each memory slot has a locking tab at each end of the slot. When you insert the memory correctly the locking tabs snap closed ensuring the memory will not come out. The beeps you are hearing are telling you the memory is not seated correctly. Same for the memory you bought. However, the memory you did buy must match the memory for the Pavilion A635W. This link will show memory you can use for the Pavilion A635W motherboard.
(Buying a new board).
The link you have posted for the ECS Gf6100-M754 MB. Will not take the memory you currently have. You will have to buy DDR3 memory but that is not the main issue. If you intend to put this motherboard into the Pavilion case it may not fit. Measure the board in the HP & check the dimensions of the ECS board you want to buy. You will have to buy a new CPU as well. The HP uses an AMD CPU & the ECS uses an Intel CPU. Basically you will be buying a whole new system including the CPU & memory, which may not fit in the HP case. You will also need a higher power supply to run the ECS board. HP's power supplies are much smaller.
Good Luck!
I will not be online here at fixya for the next week or so.
Jun 25, 2008 | ASUS A7V8X Motherboard
Replacing Motherboard with combo
You can just replace your video card. If your using the Hp A635w with the intergrated video it may have just died. You sill have a free AGP slot on the board. Buy a AGP card with DDR2 or DDR3, change the bios setting to boot to the AGP card first & Bingo! Your up & running. The HP A635w is a Micro-ATX form factor: 9.6 inches x 9.6 inches. Thats the board size & that is what you'll need to fit that HP case. Micro-ATX's limit you CPU type & speed. Like dual core's.
I've listed one board combo doing a quick search & this board will take your current memory & fit the HP case.
As I mentioned you can go for the AGP card listed in this link. Six pages of AGP's.
It's up too you pick your flavor. Enjoy!
please vote...
Feb 16, 2008 | ASUS A7V8X Motherboard
hello my friend here it is the link
to find and to download what you need
it is from asus official site so its secure,its from your mainboard,so just find exactly what tipe of downlaod you need..I suggest the user manual.youll find there the diagram for the case wires.
good again if you need something
oh..rank my answer please..;)
bye bye
Feb 05, 2008 | AMD Asus K8V-MX Socket...
ASUS A7V8X Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
