Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Stripped and stuck Bolts on Motorcycle front end
I have a 1993 Harley Davidson Sportster 1200 xlh with four stripped and stuck bolts which hold the front forks on. How can I get them off without ruining something?
The ez out is a good suggestion. but depending on bolt size and location, if might be hard to drill the pilot hole for the ez out. i have been using this proceedure for a long time and yet to have a failure. i take a nut with a hole big enough to just about to cover stuck bolt and use a mig to weld the nut to the stuck fastener through the hole and then quickly wrench the fastener out. the welding heat helps the removal process. shield the surrounding area with wet rags and to protect the point of weld, use heat sink putty available from welding supply to form a dam around the area. you can also use the putty to hold nut in place. if you get in a bind, play dough will work on a short order basis. if the fastener is sunk to deep you prpbably will need the ez out. other than that, remove fork from frame and bring to machine shop.
Posted on Aug 13, 2008
    Genius:
  • 2,028 Answers
Use an easy out, they're sold at any automotive parts store.
Posted on Aug 07, 2008
What is the Banjo bolts on the front of a 1989 Harley Davidson Sportster?
i believe it is 10 mm banjo on the sportster front brake system
Mar 22, 2015 | Harley Davidson Motorcycles
Starter drive assembly(bendix)
No you dont!
Have a certified Harley tech handle this one. Most motorcycle starters are three bolts and the battery cable, NOT Harleys!
Apr 02, 2014 | 2000 Harley Davidson XLH Sportster 883...
I need the torque specs for a 1993 harley xlh 883
Hi Jason, and your torque specs are:
1. 1/4" bolts 10 ft lbs.
2. 5/16" bolts 20 ft lbs.
3. 3/8" bolts 35 ft lbs.
4. 7/16" bolts 55 ft lbs.
5. 1/2" bolts 75 ft lbs.
Have nice day.
Apr 07, 2012 | 1993 Harley Davidson XLH Sportster 883
I have a 1993 Harley sportster and can't get the
If after u loosened the chain tensioner and it's still stuck some models have a bolt through the kickstand that also goes through to the inner primary so u need to take the kickstand completely off
Mar 18, 2012 | 1993 Harley Davidson XLH Sportster 883
Will the "Derby Cover" off
No, the '91 to '93 models have a small two bolt "inspection plate" type cover where the '94 and later models have a large four bolt cover according to my manuals.
Good Luck
Steve
Jun 19, 2011 | 1993 Harley Davidson XLH Sportster 883
How do i track down wiring harness diagrams and schamatics for a 91 1200 sportster xl
follow this link and download everything you need to know about your bike
http://www.downloadninjas.info/service-manuals/harley-davidson-sportster-xl-xlh-service-repair-manual-for-1986-2003-models/
Mar 25, 2011 | 1993 Harley Davidson XLH Sportster 883
Harley Davidson Sportster starter removal?
1997 HARLEY DAVIDSON SPORTSTER XLH 1200
STARTER REMOVAL
1. REMOVE LEFT SIDE COVER
2. REMOVE NEG. BATTERY CABLE FROM CRANKCASE TO PREVENT ACCIDENTAL STARTUP
3. REMOVE POSITIVE BATTERY CABLE
4. DRAIN TRANSMISSION FLUID (5/8" SOCKET)
5. REMOVE PRIMARY COVER (IF YOU'RE UNSURE OR IT'S BEEN AWHILE - PLEASE CONTACT - I CAN PROVIDE INFO)
6. REMOVE REAR EXHAUST
7. REMOVE 2 STARTER BOLTS (5/16" ALLEN)
8. REMOVE STARTER
9. REMOVE GASKET
10. SLIDE BOOT BACK AND DISCONNECT THE POSITIVE CABLE FROM BATTERY (12MM)
11. DISCONNECT STARTER SOLENOID POSITIVE LEAD TO STARTER
12. LOOSEN WIRE BAND NUTS 3/8" SOCKET
If anything you're unsure about or been awhile just comment below or reach out. The primary cover has a few quirks to get off - can go further with you if needed. All The Best, Justin Lee
17 South Industries, LLC
Aug 10, 2010 | Maisto Harley Davidson 1997 XLH Sportster...
How to remove starter on 1976 sportster
To remove the starter motor from you Ironhead, look at the rear of the starter motor. There are two "nuts" holding the end cap on. These are not actually nut but very long bolts. By removing these two bolts, you can pull the starter out of the starter drive housing.
But, the long bolts also hold the starter together. You have need to be careful when you take the starter out as it will fall into four pieces. The front bearing plate, the armature, the field windings, and the end plate with the brushed on it. If you're not familiar with fooing with starters, the brush plate can be confusing to get back on the end of the starter.
The starter on your '76 Sporty should be the Hitachi type starter.
Apr 02, 2010 | 1979 Harley Davidson XLH 1000 Sportster
1993 harley sportster 1200 headlight quit working
could be a bad ground in the head light bucket or the jumper from frame to the triple tree
Jul 15, 2009 | 1993 Harley Davidson XLH Sportster 883
1993 Sportster air cleaner
I assume you are talking about the 3 inner bolts that hold on the filter? If so I would advise using a cutoff tool like a dremel or air grinder cut off wheel and cut the head off the bolts or nut then remove the rest when you take off the filter.
Jun 07, 2009 | 1993 Harley Davidson XLH Sportster 883
Lands Phones Logo
59 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
