Question about Hoover Dryers
Hi, I've got an older Hoover Apollo 411 tumble dryer which has just stopped heating. It still spins but obviously doesn't dry without heat. I presume that it is some sort of element or heating coil that has gone, my question is can I buy a replacement part and do it myself or is it a specialized repair and is it worth doing in a machine that's a bit old? thanks very much, Shari.
  • 5 Answers
A good Start to clear it up is "repair clinic.com" Sounds like a heating element. Repair Guru will let you know if it is a real problem to fix.
Posted on Jun 26, 2008
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Hoover Clothes Dryer Apollo 100 D6176
Most electric dryer problems not heating are due to the heater coil circuit being broken. The wiring can be replaced by the coil kit being purchased from an appliance parts store. Need make and model numbers. Follow directions in package.
Oct 13, 2013 | Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Hoover DYC9913AX
gentlmen you need to move with the times this tumble dryer has no element it is whats caled a heatpump solution ,there is no exhaust for the air to go out of as it is a sealed enviroment the air re-circulates within the machine
Nov 07, 2012 | Hoover Dryers
No heat from hoover hnv375
If not heat at all check for open heating element.
Sep 06, 2017 | Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Working fine not getting hot where do i buy a new element and how much?hoover 411 apollo
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 30, 2010 | Hoover Dryers
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Tumble dryer doesn't dry. It tumbles but there is no heat
Either your heating element went out or your thermostat (which regulates the temp).
Jan 29, 2010 | Hoover Nextra 160 HNWF 3137 Front Load...
Not getting hot
Sounds like the heating element has broke. If it spins and doesnt produce heat its best to call someone out, or buy a new one. If nothing works, check fuses and connections
Apr 13, 2009 | Dryers
Dryers Logo
216 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
