I have Photo Studio 5.5 that was bundled when I installed a Canon product. When I am using the crop tool, after a couple of clicks of the mouse the computer crashes. A recent error report suggested that the cause was because of a driver. Is there some way for me to download a upgrade?
  • Anonymous Apr 15, 2009
    I followed the instructions below and got my program to work again! Thank you!!! I've tried so many things and I finally got the problem fixed!
    Novelist:
  • 150 Answers
Hi Chrome,
I am assuming that this is "ArcSoft" studio
you are having trouble with.
Before you read my more detailed rantings which follow,
make sure that the size of your virtual memory page file
is big enough, which is a likely quick fix, from the sounds
of things:
Right-click on MyComputer, then left click:
Properties -->
Advanced --->
Performance settings --->
Advanced (again) --->
Virtual memory change --->
Choose a hard-drive or partition with the most free space,
chose "Custom size"
Set the "initial size" = "Maximum size" =
1.5x your physical RAM or 2GB, which ever is GREATER.
press OK and reboot the machine.
(more info on paging file at the end of this article)
Also try to disable hardware acceleration on your VIDEO card
Right click on the DESKTOP,
Left click on PROPERTIES --->
Settings --->
Advanced --->
Trouble shoot --->
Follow the displayed instructions (depend on hardware)
trim back the performance slider one notch at a time
to see if it fixes the problem.
Also right click on My Computer -> Hardware ->
Device Manager ....
Scroll down the list, open up every branch and look
for exclamation marks beside drivers that do not
work properly. Right-click at the top of the tree,
and scan for hardware changes, to see if anything
strange pops up
The above instructions are for Windows XP,
these may be a little different on other versions
of Windows.
If the above did not solve your problem, read on, or if you
are just curious read on too:
1) I am running Version 5.0.0.70 and it is very stable under XP
2) My system:
a) Windows XP-Pro, 32-bit, SP2
b) Intel Core-2-Duo 6600,
c) 4-Gigs of RAM
2.7 Gigs are actually available to compitable applications,
using the /3GB switch in boot.ini.
d) Two ATI Radeon Saphire HD3600 PCIx video cards.
e) Quad DVI video display monitors 1680 x 1050
2) You may try to down-grade from version 5.5 to 5.0,
(i.e. remove and re-install) to
see if the new version has a problem, but this is not likely.
3) The easiest way to find a copy of anything is
Emule P2P or "http://thepiratebay.org/" via BIT torrents.
I am assuming that you are a legitimate owner of
the software trying to experiment or fix it, NOT a
thief, and your legal problems are your own.
www.mscracks.com has what it says, but the site is
LOADED with viruses and drive by malware scripts,
which means:
Never go there with Internet Explorer (any version) !!!!!!
Make sure that you are using the latest version of the
FireFox WEB browser, equipped with the following
security plug-ins:
1) "Finjan" Google link scanner
2) NoScript 1.6.9.3 by Giorgio Maone
The NoScript will automatically prompt you to
allow or block every new script. It also remembers
trusted and untrusted sites.
NEVER allow ANY script from a hacker site, or any
site it LINKs to. You may also need to TEMPORARILY
disable your anti-virus, if it has a blocking web-link
scanner.
The MSCRACKS site IS (very) dirty, that is how they
make their money, but it also has a huge number
of useful utilities and info. The trick is to get what
you want, without them getting you.
Visit this site only AT YOUR OWN RISK !!!!
Unless you are very good and careful, I strongly
advise against it, legal issues in your jurisdiction
must also to be considered...
Always scan everything you get from there, EMULE
and/or bit torrents with every AV scanner you can get
your hands on, before opening it.
Always scan your whole computer after going there,
or any other such risky activity.
Also, I am assuming that you own a legit copy
and just want to fix it, not steal it. I do NOT condone
software piracy. I write software for a living, and while
I do crawl through the Internet's sewers and back alleys
for learning purposes, I strongly believe that you should
pay for the software you use.
If a version downgrade does not fix the problem, like I said,
my older version 5.0 is very stable...., then we need to do a little
more troubleshooting, but for this I need a little more info:
a) What operating system are you using ?
I recommend Win XP-Pro service pack 2 or 3,
which is by far the most stable, and orders of
magnitude more efficient than Vista. It is also
mostly DRM free.
VISTA is a PIG, take my word for it.
Win 2000 is also OK.
Win ME is Marginal
Win 95, 98 are garbage, almost unusable.
Win NT-4 was great in its day, but it will not
support new hardware, large hard drives or
new software.
Microsoft no longer sells XP, but they do sell version
downgrades after you buy VISTA.
(This is quite obscene if you ask me...)
There is always Emule or Pirate Bay though.
continued in next message....
Posted on Jun 26, 2008
  • Martin J Stadler
    Martin J Stadler Jun 26, 2008
    Hi Chrome, continued from prev msg:
    b) What kind of hardware do you have:
    Image processing software needs to to a LOT of number
    crunching for every pixel: Integration, convolution ... etc.
    The amount computational work also increases with the
    SQUARE of the resolution. This means that if you double
    the resolution or image size in both directions, the computer
    requires 4x as much memory and CPU time to do this.
    When the computer runs out of Physical (on-chip) RAM,
    it starts swapping data on and off disk. This is called
    paging, and if it happens too much it is called THRASHING.
    THRASHING is (very) BAD, because it wears out you HD,
    and because it consumes an extreme amount of time.
    Assuming that a typical RAM location can be accessed in
    1 nano-second or so, and a typical (fast) hard-drive has an
    average access time of 10 milliseconds, that hard drive is
    10 million times slower than RAM, and a task that would
    take 1 second in memory, can take up to 15 days on disk.
    Clearly, the hard disk is NOT the place to store transient
    photo computations.
    When the computer runs out of PAGING file space as well,
    (that was the setting we checked first)
    the application dies. Period ! Depending on the application
    and the OS, it can also take down the operating system
    with it.
    For serious photo editing I recommend the following minima:
    a) Pentium 4 at 2 Gigahertz or equiv. with windows XP
    The fastest core-2-duo you can by with VISTA,
    because VISTA will slow you machine down by at
    least 4:1.
    The best is to avoid VISTA like the plague, and
    get XP-Pro or (XP 64 if your processor can handle it)
    b) The Full 2 Gigabytes of RAM on a 32 bit system,
    4 Gigs on a 64 bit system.
    N.B. Windows 32 normally splits its theoretical
    4 Gig address space into half.
    The lower half is available to the user and applications,
    while the upper half is used by the OS Kernel, and also
    reserved by memory hungry hardware like video cards'
    on-board RAM, which is mapped over the SYSTEM's
    address space.
    If you install 4 Gigs into a 32-bit system, it is possible to
    change this address space split from 2+2 to 3+1, by
    appending the "/3GB" switch to the operating system's
    path in the "boot.ini" file.
    The /3GB switch has some restrictions:
    You must disable 64-bit memory remapping in the BIOS,
    because this conflicts with the 3/GB switch on a 32-bit
    OS
    You may NOT get the full 3 GB, if your video cards have
    already claimed some of that address pace for its own
    RAM. For example on my system I can only get about
    2.7 gigs = 4 Gigs - Video card #1 (512 M) - Video card #2
    - OS kernel.
    Standard 32-bit applications cannot accept more then
    2 Gigs of memory, unless they are 4 Gigs aware.
    This can be achieved by either re-compiling/linking
    the original application with 4Gig switches, or by
    passing the EXE file through a re-link utility, such as:
    Imagecfg.exe
    Multiple apps CAN access different chunks of this additional
    space though, up to 2 gigs each.
    The bottom line is you should have no less than 1 Gig,
    and optimally at least 2 Gigs of physical RAM for photo
    editing, ther is no getting away from this.
    Then you should set aside at least 4 Gigs of hard-drive
    space for a virtual swap file, when physical memory runs
    out. This swap file should be on a separate hard disk from
    your Windows and from the Photo Application for best
    performance. It should also be on its own partition to
    prevent fragmentation of other stuff, and it should be
    a fixed size swap file for the same reason. Don't let
    windows manage it.
    (Some useful system tuning:)
    If you put the swap (paging) file on a different partition,
    but on the same physical drive as Windows, then the
    paging will be slower, since the physical head has to
    travel farther from windows to get at this paging file,
    but this is better than suffering the fragmentation that
    occurs if ti is on the same partition as windows.
    In this case, sandwich the swap file partition half way
    between the windows and application partitions, and place
    user files on a partition of its own
    see Acronis Tools, or Norton Partition Magic for re-
    partitioning.
    z) Finally, never run multiple applications during image,
    processing, especially on older, smaller, slower systems.
    Give as much resources to the Photo app as you possibly
    can.
    Conversely, limit the size and resolution of your pictures to
    fit into what your machine can handle. Don't assume that
    an image only takes 5 Megabyte, like the size of its file.
    JPEG for example, uses a lossy image compression
    algorithm, which can reduce its file size by a factor of
    20 or even 50:
    (Lossy quantized modified Discrete Cosine Transform,
    followed by lossless entropy compression)
    The problem is that most photo editing operations cannot
    be performed on the original file, and the image must be
    de-compressed in memory, and re-compressed when saved.
    To get what it takes to store an image:
    Memory size = No. of horizontal pixels x
    No. of Vertical pixels x
    3 colors + 1 Alpha x
    (2 or 4 bytes per color) x
    Note that 24 bit color actually takes 32, due to word alignment,
    and the alpha channel (transparency) does not apply to
    all formats. This amount of memory must also be multiplied
    by the number of active layers, by the number of open files,
    and by two when editing, to keep the old and new version,
    which is necessary for convolutions, rank filters, cutting,
    pasting, etc.
    so a single 4096 x 3072 x 24 bit (4 byte) color pixel image
    (without alpha) = 50 Mega bytes.
    This means that you need at least 100 megabytes to edit it.
    add a layer, and you are up to 200 megabytes.
    double the size ==> 800 megabytes.,
    on top of windows and the application.
    the 1024 or 2048 physical limit sneaks up on you real fast.
    Hope this helps, get back to me with your system info
    if this (general help) did not solve your problem.
    Please rate my answers.
    Martin
How to edit picture?
Hi
You don't say which operating system you are using.
Photo Editing requires Photo Editing Software.
To do basic photo editing (cropping, rotating, flipping, adjust brightness, adjust contrast, adjust image size, adjust colo(u)r, adjust exposure, adjust size, adjust red eye) you can use free, built-in software that comes bundled with Windows and Microsoft Office such as: Paint, Microsoft Picture Viewer and Windows Photo Gallery.
In increasing order of editing functions:
Windows Photo Gallery: Fix > Auto Adjust, Adjust Exposure, Adjust Colour, Crop Picture, Fix Red Eye
Microsoft Office Picture Viewer: Picture > Brightness & Contrast, Colour, Crop, Rotate, Flip, Red Eye Removal, Resize, Compress.
Paint: Image > Flip/Rotate, Resize/Skew, Crop, Invert Colours, Adjust Attributes, Clear Image, Opaque.
In Paint you can also use additional tools to manipulate the image or add or delete shapes, text and colour (with a selection of writing or drawing implements): Free Form Select, Select, Fill with Colour, Magnifier, Brush, Text, Curve, Polygon, Rounded Rectangle, Ellipse, Rectangle, Line, Airbrush, Pencil, Pick Colour, Eraser/Colour Eraser.
In Windows Photo Gallery you can view and edit the same image in either of these 3 programs by clicking Open.
For more advanced photo editing, you can use the bundled software that comes with digital cameras such as:
Adobe Photoshop Elements
ACDSee
Picasa
Photo Studio
For more advanced, professional standard photo editing you must buy expensive Photo Ediiting and Graphic Design software such as:
Adobe Photoshop
Adobe LightRoom
Adobe Illustrator
Adobe InDesign
CorelDRAW
Corel Painter
I hope this helps.
Aug 26, 2011 | Computers & Internet
Pictures appear 6 x 4 when developed on my Canon Selphy DS810. How can I change them to be developed 4 x 6 instead. I have pictures that have heads chopped off when developed 6 x 4. If I can change them...
What program are you using when you "develop" these pictures. I would recommend paint shop pro for all your photo/image editing needs. Once I have more information I can assist you further so please don't reject my help.
Thanks,
Lee
Aug 15, 2008 | Canon Cameras
How to enlarge/reduce photo size & maintain proportions
I think you are referring to "crop".
After pasting the picture in MS Word,
You would see "Picture Tools" top tab. Then under "Fomat" you would see "crop" click on it and try editing your picture.
It should reduce the size of your picture and maintain the normal image size.
Hope this helps.
Thanks,
Jul 17, 2011 | Microsoft Office Word 2007 Full Version...
Can't download video?
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General video", then select an MP4 format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP4, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No Adware. Do not hesitate. Have a try!
Aug 02, 2010 | Canon HG10 HD AVCHD HD Camcorder
I needed to crop in my photo
There should be a crop button at the top, where the tools are, just hover over them till you see Crop. Click it, it will then ask you to select an area that you want, basically, it gets rid of the rest of the photo not selected by you. Hope this helps.
Here is a link to "How to Use Adobe Photoshop CS3"
http://www.photoshopsupport.com/tutorials/cs3-photoshop-10.html
May 15, 2010 | Adobe Photoshop® CS3 Extended Full Version...
Asure ID Express hangs up in image editing mode, before printing.
The problem turned out to reside in the software itself. The company was aware of it and promptly provided a fix.
Sep 01, 2009 | Synercard Asure ID Express
Crop the photo in diffeent shaps like heart.
The crop tool will not let you crop in shapes like elements cookie cutter tool will. However, there is a work around to do what you want to do which indecently is the same as you would have to do in Photoshop CS4.
1. Create a new document file or press Ctrl + N.
2. Open an image you want to crop.
3. Press Ctrl + A then Ctrl + C to copy the image.
4. Select the new document file you created and press Ctrl + V to paste the new image in a new layer.
5. Select the Rectangle tool or press U for the hotkey.
6. Move the mouse over to the Rectangle Tool and hold down the left mouse button and select Custom Shape Tool.
7. At the top of the menu you will see a Shape: icon with a pull down option. Left Click on the arrow to expand the window to select the shape you want. If you want more shapes to choose from when the shape window is displayed click on the arrowhead with a circle around it and select a new library or all.
8. Use the mouse to draw the shape to the size and location you desire.
9. The shape will be in a new layer with a mask which will cover the image. Hold down the Ctrl key and left click on the Shape 1 layer in the layer window. This will mask the shape and only the shape.
10. Press Ctrl +Shift + I to invert the mask selection.
11. Use the Select pull down menu to Feather, Modify, Contract, Expand and Border if you want apply those effects around the edge of the mask.
12. In the Layer window click on the eye next to the Shape 1 layer to hide the image.
13. Select the image layer you want to crop and press delete which will delete everything outside the custom shape you created.
14. Do not forget you can right click on the image layer and select Blending Option to add drop shadows and other special effects for the cropped shape.
Jun 05, 2009 | Adobe Photoshop 7.0 for PC
Bamboo Fun won't work w/ provided software
I think you need to select the right tool to use with the tablet, I like to use the tablet with the lasso tool. If you want to draw use Adobe Illustrator. If it works as a mouse I think you just need to learn how to use the software you are dealing with.
Apr 11, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Reduce the size of a picture
Try downloading a free program like paint.net (www.getpaint.net), open the photo in it, find image size in one of the toolbars (usually the image toolbar) and setting it to 2 inches
Dec 07, 2007 | Canon PowerShot S5 IS Digital Camera
Computers & Internet Logo
608 people viewed this question
David Payne
David Payne
