Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Input My menu video shows up correctly, but any video input comes through as vertical pink and white lines.
  • JVC Master
  • 8,617 Answers
You need a new singal board. If you need more info or where to get one please let me know but respond to this same post.
Posted on Jun 26, 2008
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Just bought a acer h7531d dlp projector. From the first run, it shows vertical white lines even without a video source and these lines seem to drop a shadow on the video. Is this a serious issue? Didnt...
I have found that it has something to do with the ribbon between the controls and the motherboard. I had white lines which I can make come and go by adjusting the ribbon. I still have fine black line.
I just unhooked the motherboard and reseated it. Now the projector is working 100% correctly. I have not closed the case yet. It'll probably glitch on me when I do. So in my estimation it isn't that any one part is bad but rather that there are faulty connections. Getting all cable seated properly should be the fix.
It is all together and working perfectly.
Jan 21, 2012 | Televison & Video
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Samsung hl-r7178w has green video and vert. lines on all analog inputs, hdmi input is good and menu screen is good
Hi,sounds like It could be the DMD board.This is how the DMD board works: http://electronics.howstuffworks.com/dlp1.htm Basically when that Dmd chips starts to fail that's what you'll get color discoloration vertical lines, white spots.You will need to replace the dmd only you can find it on ebay,samsung,or shopjimmy.com God bless you!
Oct 05, 2009 | Samsung Televison & Video
Line pink and green
this would definitely won't be the lamp, the issue is either with you video board or the dmd board, go to the menu and if that line still shows up on the menu, the issue will be with your dmd board, on the contrary the issue would be with your digital video board
Jul 21, 2009 | Samsung HCN436W 43" Rear Projection...
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Vertical white lines across screen
whatever brand your tv is go there .com maunals it should show u what u need to know
Jul 14, 2008 | InFocus ScreenPlay 61" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
20 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
