Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Antenna for my HDTV
I have a 53" panasonic HDTV and I just ordered Directv for my home. They don't offer local channels where I live so I have to resort to using an antenna for my locals.
Now, do I need to purchase a regular antenna or do I need to get a HDTV antenna? The stations in town are broadcast in HD, so I am under the assumption that its just my personal preference? Right? Wrong? Can you suggest some good antennas for the money?
Also, is there anything else I need to buy and install with my antenna? Cables? An amplifier(whatever that is)? Tuner?
As you can tell I am pretty clueless. I would appreciate any advice you can offer me. Thanks.
Chris
  • Panasonic Master
  • 520 Answers
Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
Posted on Jun 26, 2008
Sound on one channel from over the air antenna has suddenly become garbled. All others are fine.
If only one channel is affected it is not a problem usually with the set--it does not know what channel you are on---look in audio menu and make sure if set has SAP it is not on.
Nov 05, 2012 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Do I have to subscribe to directv to get any high definition stations?
DirecTV provides the most HD content. But no, the correct off-air antenna may pull in local HD stations, depending where you live. Also, cable and DishNetwork provide HD channels.
Sep 05, 2012 | Vizio 32" e321vl flat panel 720p 60hz...
Programming channels for TV viewing?
You can often find the digital channel numbers for your local stations in a guide like http://www.titantv.com/ or https://tvschedule.zap2it.com/?aid=gapzap . Alternately, check if the local stations websites offer a link to their schedule. This will usually list the channel/channel digital identity. Another source for the digital channel numbers are the antenna choice/position/direction guides. Look at http://www.antennaweb.org or http://www.tvfool.com . Tvfool.com gives the direction and signal strength for all channel transmitters in your general area. Antennaweb.org is much more conservative and will only give the strongest stations in your area. That conservative list assumes an external antenna and clear path between the transmitter and your antenna.
In my area, the analog channel 7 became digital channel 7-1 . However, the channels 12 and 16 now transmit at 43-1 and 46-1 . However, after letting the TV do the auto-search, they are 12-1 and 16-1 when I type in the channel numbers on my remote.
I hope this helps. I might be able to provide a list of your local digital channels if you add a comment with your general location.
Mar 04, 2018 | Panasonic TH-42PC77U TV
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
My Panasonic 47 inch rear view projector is hdtv ready, what do I need to buy to recieve pictures in HD
You should be able to receive the HD signal from your cable company. If you are still receiving your signal over the air, then you can buy an HD tuner. I found mine at Best Buy for $179 a few years ago. It will come with component outputs which is the HD signal.
I'm using my 70's vintage antenna on my house to receive the 3 local channels in HD.
Good Luck,
Jan 19, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
TV antenna
Hi splhcb,
Your television is already an HDTV, meaning it is set up for receiving digital broadcasts. In this case, you should not need a separate converter box for over-the-air reception. You will need an antenna, but the type you purchase depends on things like how far you live from broadcast towers, landscapes, buildings, and where it will be located in your home. Although many antennas are being marketed as HDTV compatible, if you already own an antenna you likely can continue using it. Otherwise, it is best to speak with someone at the store who can weigh the factors in your situation to recommend the best antenna.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 28, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
293 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
