Question about GE JBP90 Electric Kitchen Range
OVEN DOOR LIGHT SWITCH
HOW DO I CHANGE THE SWITCH ON MY OVEN DOOR FOR THE LIGHT
  • 4 Answers
These instructions apply to my GE Profile JBP90 but other brands and models are similar.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Posted on Nov 22, 2008
GE Adora JGB605DET3WW after self clean door would not unlock. Tried shutting of breaker but after turning back on still the same. Replaced door lock motor with another one and circuit board and still...
Press the oven light switch in and see if the it returns to normal. The oven light switch is part of the self clean circuit and it is is not depressed or not working then it could be the entire problem. If pressing the switch in cures the problem, then the switch is working fine and the clock oven control will need to be replaced. Happy New year and have a wonderful day. Oven light switch part number WB24K10068, Oven control part number WB27K10319. when changeing out this part you have to remove the overlay with button description on it and transfer to new clock, try gentel heating it before trying to remove or the paint will rip off and you will need a new overlay here is the part number just in case WB27K10408
Dec 26, 2017 | GE Ovens
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
We need to slam the oven door to switch off the intenal light and make the oven work?
cleaning your oven door switch might help but I would consider replacing the switch. The switches are sealed and cleaning does not work well.
http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Smeg F65 Stainless Steel Electric Single...
Start button an 1/2 buttons on keypad no work in my GE JVM150H microwave. Interior light also stays on.
The door has latch switches that are part of the protection and operation when door is closed, is the new door identical and switches match up {same number} if everything checks and the door switches are all working, the door needs to be checked for alignment, if it's out a small margin the switches will not operate properly.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Jen-air electric oven jjw8530. Door will not shut all the way. Light stays on. Hindges have been replaced twice. Not hindges! Help!
Bubbcrk,
Is your door lock in the way? I think that your model has one correct? Have you checked the door light switch? If it is the switch that is keeping the door from shutting and turning the light out, you can get one fairly cheap.
Please Clarify.
Door Light Switch for your model
http://www.pricedrightparts.com/products/Door-Light-Switch-PRP71002904.html
Thanks Joe
Jun 11, 2011 | Ovens
Oven light and "door open"
Sorry to read about your problem, I hope this helps you out.
push door tight with hand..if does not go off, you have a defective door switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Whirlpool RBS275PD Electric Single Oven
Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Apr 16, 2009 | Frigidaire 30 in. Electric Gallery Series...
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
GE JBP90 Electric Kitchen Range Logo
240 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
