Question about Lexmark Color JetPrinter Z23 InkJet
MY INKS ARE NEW IN MY PRINTER AND WHEN I PRINT IT LOOKS LIKE THEY ARE RUNNING OUT BUT THEY ARE NEW
  • 69 Answers
Are the cartridges prperly seated in the cradles?
When you go into the settings/ printer and OPEN file is it showing that there is a document to be printed? If there is'nt one it means that the data is not getting transferred from PC to printer. Is the lead from the PC to printer good condition and connection good?
Posted on Oct 03, 2008
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
New ink cartridges but it looks like we are running out of ink
first you try with cleaning th catridge and give the print command in best mode in printing properties.
Jan 20, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When i print the ink is so light it looks like a blank sheet
get some paper towels and boil some water put in in an old coffee cup. hold the ink cartridges over the water (not in) the steam will clean out the nozzles on the cartridges. the ink will run a lil bit (hence the paper towels) give the printing a go again.
hope this helps..
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The tank 3eBK black do not print
olofossonbygg,
Looks to me like an air lock in the system.
Have you just changed the black cartridge because of an error message and did it print up to the point where you just changed it?
Just replacing the cartridge with a new on can sometimes lead to an air lock in the small ink feed system.
Does your cartridge have the writing head at the bottom or is it just an ink tank, in which case it could defiantly be an air lock.
Try a cleaning cycle, and leave the printer for a few hours to stand and let the air lock escape naturally. Running loads of cleaning cycles will use a lot of ink, so don't be too hasty.
Sep 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Most of Group 1inks,(except red) won't print
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Sep 10, 2009 | Canon i9900 InkJet Photo Printer
Printing wrong colors
you might be running out of the red ink.
Whenever a printer prints the whole image but with different colors it means that the printer uses the available color with enough amount.
Try replacing it with new ink cartridge.
Jul 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Looks like it is running out of ink...
Hi I am Vortash it sounds like your printer needs a good doush with ink flush as build up of dried ink in the head and pipes will cause this type of problem also clean the head mount and head with methalayted spirits to clear blockages regards Vortash
Jun 30, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Black ink looks faded!
Providing that the ink cartridges were new and supplied with the printer, the cartridge is defective. I also don't think that you used up all the ink either unless you printed hundreds of documents already. Take the cartridge back to the store where you got the printer from and they should give you a new one.
Oct 29, 2007 | Dell 810 All-In-One InkJet Printer
Printer problem
Hi, after you install a new ink cartridge you need to run the printer software to add the new ink levels. Have you done this?
Sep 15, 2007 | HP DeskJet 680c InkJet Printer
Test print great, document printing blurred
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Sep 02, 2006 | HP DeskJet 3325 InkJet Printer
Lexmark Color JetPrinter Z23 InkJet Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
